EGR Valve | ECU Code 80
Old Aug 5, 2006 | 11:18 AM
g3teg97's Avatar
Default EGR Valve | ECU Code 80
Short question: Do Integra's have EGR valves?
Long question: Does it have anything to do with ECU Code 80: Exhaust Gas Recirculation?
Old Aug 5, 2006 | 04:02 PM
95 integra's Avatar
Default Re: EGR Valve | ECU Code 80 (g3teg97)
Nope, no EGR....atleast not on any integra Ive owned.
Old Aug 5, 2006 | 05:06 PM
CASTUDILLO01's Avatar
B SERIES DON'T HAVE EGR VALVES
Old Aug 8, 2006 | 05:10 AM
g3teg97's Avatar
What is going on with this? What do I do about code 80?
Old Aug 8, 2006 | 07:47 AM
Smog09's Avatar
Default Re: EGR Valve | ECU Code 80 (95 integra)
Ls models have Exhaust Gas Recirculation valves. Lool under hood for emissions label, it should read 02, Catalyst, if equipped with EGR should say EGR.
Old Aug 8, 2006 | 11:14 AM
95 integra's Avatar
Default Re: EGR Valve | ECU Code 80 (Smog09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smog09 &raquo;</TD></TR><TR><TD CLASS="quote">Ls models have Exhaust Gas Recirculation valves. Lool under hood for emissions label, it should read 02, Catalyst, if equipped with EGR should say EGR.</TD></TR></TABLE>
Neither of the LSs I owned had that crap, now the SC300 has it, but no teggy.
BTW, since you have a 97 model you should have the PXXXX code, not a "80."
Old Aug 8, 2006 | 03:25 PM
g3teg97's Avatar
The light blinks for a second and does this eight times. As far as I know a long blink means 10 and a quick one means 1.
Old Aug 8, 2006 | 06:02 PM
95 integra's Avatar
Default Re: (g3teg97)
take it to autozone and get the OBD II port scanned, the codes that you are pulling are ment for OBD I motors.
gperry322
Jul 3, 2008 03:53 PM
g3teg97
Jul 11, 2006 04:01 PM
TheAccordGuy
May 28, 2006 09:46 PM
Linh.
Dec 10, 2005 10:03 AM
lakerschamp2000
Mar 7, 2004 02:17 PM
