do i need to replace my alternator?
Old Aug 5, 2006 | 09:46 AM
clemsonteg's Avatar
Default do i need to replace my alternator?
just for reference this is a 98 civic ex
Ok so I pulled out my multimeter and my haynes manual so i could test my charging system because I have reason to believe that is causing my dropping idle. The manual reads that with the ignition off the battery should read about 12.5, i got a reading of 12.49-12.51 so that was good, the next step was to turn the car on and rev to 2000rpms where it should read between 13.5-14.5, for the first few seconds i got a reading of 14.25, but then it dropped to 12.51 like the original reading, i also tried turning on some of the accessories like the ac and not much changed, it would appear that my alternator is putting out enough to keep things going but not enough to get it all the way up, so what do you guys think? Before i did the testing myself I had a previous notion something was wrong when i went to advanced autoparts and they tested my battery and they said it had the right voltage but a low charge
also according the the manual in the case of replacing the alternator i must remove the axle, is that necessary or is there some way to remove it without taking out the axle?
Old Aug 5, 2006 | 09:50 AM
Shake and Bake's Avatar
You have the same model as me. I didnt remove the axle, it came out right through the top. Took me about 30 mins topps. You just have to remove the top bracket and your golden
wheelmanbg's Avatar
Default Re: do i need to replace my alternator? (clemsonteg)
My guess is that you could use a new alternator..
And I've never done one in a 98 but I suspect the only reason they say to take the axle out is so it is easier to get the alternator out of the engine compartment but you might be able to do it without doing that
Old Aug 5, 2006 | 09:54 AM
SOHC_me's Avatar
Default Re: do i need to replace my alternator? (wheelmanbg)
while your car is on unplug the battery if it shuts off you need a new altonator.
Old Aug 5, 2006 | 10:06 AM
clemsonteg's Avatar
Default Re: do i need to replace my alternator? (SOHC_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">while your car is on unplug the battery if it shuts off you need a new altonator.</TD></TR></TABLE>
ill try that, not do i remove the power cable or ground cable?
Old Aug 5, 2006 | 10:10 AM
HNP's Avatar
HNP
if u gonna change ur alternator disconnect ur battery..
Old Aug 5, 2006 | 10:49 AM
SOHC_me's Avatar
Default Re: do i need to replace my alternator? (HNP)
**** i dont remember, but i think you remove the power, the red one.
Old Aug 5, 2006 | 10:57 AM
wheelmanbg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">**** i dont remember, but i think you remove the power, the red one.</TD></TR></TABLE>
correct
Old Aug 5, 2006 | 11:11 AM
clemsonteg's Avatar
ok so i just removed it and the car continued to run without a hitch, what could that mean, is it possible i might just need a new battery?
Old Aug 5, 2006 | 01:30 PM
bsixteen's Avatar
have you tried to clean your IACV? its mentioned a lot on here when ppl talk about unusual idle.
Old Aug 6, 2006 | 05:52 AM
clemsonteg's Avatar
Default Re: (bsixteen)
yeah i cleaned it, it was filthy but it looks much better, honestly i have had the same idle problem with any honda i have ever owned and recently it hasnt been as bad, but i been getting some crazy light dimming at night so that maybe due that i need a new battery or i need to sand the surface contacts for my grounds
Whatislove
Honda Civic (2001 - 2005)
Dec 5, 2008 10:47 AM
ED6JDM
11
Nov 7, 2006 07:49 PM
vteg
Audio / Security / Video
Jun 29, 2003 03:31 PM
3gLudeH22A
Aug 12, 2002 11:16 AM
tinkerbell
Jun 12, 2002 05:15 AM
