REAR MAIN SEAL OR DISTRIBUTOR
Old Aug 5, 2006 | 09:02 AM
El pimp chulo's Avatar
Default REAR MAIN SEAL OR DISTRIBUTOR
well i just wrote a topic about my oil leaking some said rear main seal big job and alot of money so i called Garage kwai where they did my swap and they said sometimes the distributor O ring can leak oil and maki it look like ite th rear main seal is this true? any way i can check . i dont see any oil under the distributor or on top of the tranny ahh im so confused and i have no money
Old Aug 6, 2006 | 12:47 PM
CASTUDILLO01's Avatar
Default Re: REAR MAIN SEAL OR DISTRIBUTOR (El pimp chulo)
if your leaking oil you can buy dye for oil and pour it and wait a week to see where its coming from make sure you clean all the oil off the motor so you can pinpoint it lot easier. common oil leak from b serise is the cam plug seal and the distributer seal but not as common as the cam seal.
Old Aug 6, 2006 | 01:27 PM
sirg-vtec's Avatar
B series are known for cam plug leaks. My cam plus is leaking. May its that?
Old Aug 6, 2006 | 04:09 PM
95 integra's Avatar
Rear main isnt a common leak, but you should see a leak on the head if its the distributor or cam seal.
thundernoodle
Aug 20, 2010 02:22 PM
MumBleZ_94gsR
Aug 4, 2009 11:50 AM
garyc17
May 2, 2008 03:31 AM
whatan00b
Apr 21, 2008 12:33 PM
quikrpm'z
Mar 5, 2003 09:41 PM
