what should I do next?
Old Aug 5, 2006 | 06:05 AM
dailydriven's Avatar
Default what should I do next?
Ok basically I have never made it this far with a car...I have built the engine/suspension/tranny as much as I know how to with my knowledge...now my question is....where do I go from here?
I done some basic things with fuel like injectors and I am thinking of getting a fuel pump. However, fuel and ignition are probably one of the few things I know nothing about since I have never made it this far with a car.
I was thinking about upping my comp ratio (I am staying on pump gas). I want to keep it a daily driver. Any insight at all would be greatly appreciated thanks.
Engine
JDM ITR Bottom End w/ balanced GSR crank (lighter)
GSR Head
USDM ITR Trans w/ OEM LSD
Jun3 Cams and valve train
AEM 3” Cold Air Intake
Erick’s 70mm Throttle Body
Edelbrock VictorX Intake Manifold
Benen Fuel Rail
RC 310 Injectors
B&M FPR
Fuel Pressure Gauge
Hondata IM Gasket
OEM Head Gasket
JDM ITR distributor
JDM ITR shifter/linkage/bushings
Urethane Motor Mount Inserts
Fluidyne Half Radiator w/ Fan on front
Spec Stage 3 Clutch (6 puck sprung)
Spec 7lb Flywheel
OEM Integra Axles
Cusco Oil Catch Can
SMSP Copy Header
Benen Custom Exhaust Piping with resonator with 5zigen tip, no cat.
N1 Crank Pulley (race pulley, alternator only)
Spoon Magnetic Drain Plug
Complete Wire Tuck under hood
No Power Steering
No A/C
Hondata s200
P72 ECU
Interior
Skunk2 Shift ****
Integra black seatbelts
No Sound Deadening
Black Rear Panels
Black Rear Seats
Black Carpeted Custom Cover
Optima Red Top Battery in trunk
No Roof Liner
JDM ITR Cluster
Autometer A/F gauge
New Black Carpet
Suspension and Brakes
Tein HA for an ITR
ITR Rear LCA
ITR Rear Sway bar w/ Beaks Mounting Kit
LS Front Sway Bar
Z-Speed Traction Bar
Benen front lower bar
Benen Front 3-Point Strut Bar
Benen Rear Lower Tie Bar
Benen Rear Upper Strut bar
Benen C-Pillar Bar
Benen Strong Bar
Integra GSR Front and Rear Brakes
Skunk2 Extended Lug Studs
15/16th Master Cylinder
40/40 Brake Proportioning Valve
Old Aug 5, 2006 | 09:01 AM
Old Aug 5, 2006 | 10:09 AM
UncleD's Avatar
Default Re: (dailydriven)
So uh, what are you asking here?
Old Aug 5, 2006 | 10:22 AM
Default Re: (clean rice)
I am looking for more power and I dont know what my next step should be.....? What more can I do?
Old Aug 5, 2006 | 10:24 AM
Mad Money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">So uh, what are you asking here?</TD></TR></TABLE>
I think he is trying to tell us that the new carpet and no roof liner are considered mods?
Old Aug 5, 2006 | 11:12 AM
k00lt1nt's Avatar
Default Re: what should I do next? (dailydriven)
TUNE TUNE TUNE!
Old Aug 5, 2006 | 05:51 PM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Money &raquo;</TD></TR><TR><TD CLASS="quote">I think he is trying to tell us that the new carpet and no roof liner are considered mods?</TD></TR></TABLE>
are they not modifications to the car?
Old Aug 5, 2006 | 06:00 PM
UncleD's Avatar
Default Re: (JakeIsCool)
If he hasn't tuned it yet then I would tune it. If you've already tuned it, then I would ask what your budget is. And get rid of those Rota's and buy something real.
Old Aug 5, 2006 | 06:23 PM
jakeiscool's Avatar
Banned
change the wheels next. please.
Old Aug 5, 2006 | 06:26 PM
Top Ramen's Avatar
Next big step is to port the head. The cylinder head is where the power is made. And get some cam gears.
Good luck with your project.
Old Aug 5, 2006 | 07:03 PM
Nick M's Avatar
The OEM integra axles are neato but this forum is more tech oriented. If you have a specific question, please ask. But general stuff like this rarely productive.
cjohnson_2
Jul 26, 2007 02:19 PM
dailydriven
Feb 14, 2007 01:51 PM
dailydriven
Dec 10, 2006 08:16 AM
dailydriven
Sep 27, 2006 12:08 PM
adqnnlude
Jul 16, 2006 11:56 AM
