Rebuilding my LS motor!
Old Aug 5, 2006 | 04:35 AM
2ndGenTypeR's Avatar
Default Rebuilding my LS motor!
im going to rebuild my LS motor anyone know if it would be cheaper to find another motor or just rebuild that one I want it to be faster than the stock LS so any Ideas?
Old Aug 5, 2006 | 04:58 AM
atg1290's Avatar
What do you mean by faster? Are you going full stock or aftermarket?
Old Aug 5, 2006 | 06:09 AM
Default Re: (atg1290)
Im wanting to go ahead and beef up the motor while its apart.
Old Aug 5, 2006 | 08:06 AM
unknown0001's Avatar
Default Re: Rebuilding my LS motor! (2ndGenTypeR)
If you want to have a quicker LS engine then you have a few options to consider.
-Tranny - have you considered getting an sir/gsr/itr transmssion? that right off the bat will help you put power down quicker then the long gearing in the ls tranny.
-Lighten rotating assembly - a lighter flywheel will help acceleration, also throw in a lighten crank pulley(such as the ctr n1) or a factory ls-crank pulley with the PS/AC shaved off to keep the harmonic balancing on the peice.
-Internals - you can do the bottom end with usdm/jdm b16 pistons which will bump up the compression, but to make use of the CR upgrade, you should consider getting some lumpy cams to make power.
Getting valve springs/retainers and a set of crower non-vtec b18b cams will do you some good.
-I/H/E - Intake/Header/Exhaust combination can give you some more power thats being restricet by the 1.75" factory exhaust. I'm running a b18b with a fresh stock rebuild, with a 2.5" collector/high flow cat and 2.5" exhaust piping and it's just good for now till I put in some more money into the engine. 2.5" or 2.25" will do fine for an exhaust setup
good luck with the build
Old Aug 5, 2006 | 08:38 AM
Default Re: Rebuilding my LS motor! (Mr.RHTuner)
ty
DC5StylZ
Oct 3, 2006 03:28 PM
96civich22
Aug 5, 2004 07:10 PM
redteg
Mar 26, 2003 02:36 PM
DC2_R
Jul 17, 2002 08:57 PM
