JDM H22 Radiator fan timer
Old Aug 4, 2006 | 10:38 PM
skinnyboy's Avatar
Default JDM H22 Radiator fan timer
ok i have just converted my BA8 Auto to a JDM H22A with manual gearbox. My questionis, there was a small black box next to the ecu which is the Radiator Fan Timer. Now doing my swap i changed all the harnesses to the JDM ones i got with the engine, including engine, cabin, the lot basically. Now on my cabin main harness, theres no plug for the radiator fan timer, does the JDM P13 have it built into the ECU? Also the harness is from a 93 model, whereas my cars a facelifted 94, the centre console switch loom seems to run to the side harness where as my old harness they came down the tunnel. should i use a JDM harness for this section or just rewire the hazard lights and foglight switch in manually?
GSR_ITR_BOIB
Sep 6, 2011 04:10 PM
no2unenolife
Mar 10, 2005 06:28 PM
