Clutch master Cylinder replacement HELP!!
Old Aug 4, 2006 | 09:08 PM
Flip.'s Avatar
Default Clutch master Cylinder replacement HELP!!
OK So heres my problem.
I'm replacing the master cylinder in my 94 Prelude. I have rounded off the 12mm nut on the MC.
I am useing a 12mm brake line spanner also. I have tried use vice grips but that didn't work.
Dose anyone have any ideas on how I can get this off within dammaging the fluid line? I really dont want to weld a spanner on there because I dont know how to replace the whole line.
PLEASE HELP!!
Thnaks ppl
Old Aug 4, 2006 | 11:06 PM
sporkcrx's Avatar
Default Re: Clutch master Cylinder replacement HELP!! (Flip01)
you can cut it off, put a new nut on, and reflare the line.
Old Aug 5, 2006 | 11:25 AM
Tripz's Avatar
New User
man, same thing happened to me a couple nights ago when i was replacing my cmc. I rounded the 12mm a bit using a wrench and vise grips but in the end i ended up spraying WD40 and letting it soak in for a while....then tried the vise grips again (clamp it really tight.....use slip joint pliers to close the vise if possiable) and it broke free. What makes it worse is, the space is tight...Good luck!
Taylor Foster
Transmission & Drivetrain
Aug 26, 2017 12:38 PM
chris89
Nov 14, 2014 06:53 PM
92lxsleeper
Sep 25, 2011 02:38 PM
rhdins
Nov 3, 2009 03:22 AM
digital sol
Dec 24, 2005 02:26 PM
