SRS Reset
Old Aug 4, 2006 | 06:38 PM
pumafeet10's Avatar
Default SRS Reset
Ok so i put a new clock spring ( cable reel) in my 96 accord and tried to do the corssed wire trick to reset the srs and no go it wouldn't do anything. I am positive that it is all working since my horn wasn't working before and now it is. all was put back correctly according to the helsm manual aka the bible for accords, so what do i do know??? I don't want to have to go to the dealer and im praying something else isn't wrong with me srs!!! arg!!
Old Aug 4, 2006 | 06:46 PM
hondaccord's Avatar
Default Re: SRS Reset (pumafeet10)
sorry to say but I had to take mying to the dealer. although they cleared it for free, and it only took like five min.
Old Aug 4, 2006 | 08:37 PM
pumafeet10's Avatar
Default Re: SRS Reset (hondaccord)
i have heard a few people say that they had done that, but im not sure about mine as i didn't check but wanted to see if anyone else had something to say on the situation. since as you can imagine doing this saved me like 400 and i don't want ot put more money into stealership any more!!
Old Aug 5, 2006 | 01:25 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumafeet10 &raquo;</TD></TR><TR><TD CLASS="quote">i have heard a few people say that they had done that, but im not sure about mine as i didn't check but wanted to see if anyone else had something to say on the situation. since as you can imagine doing this saved me like 400 and i don't want ot put more money into stealership any more!!</TD></TR></TABLE>
i did it on my 02 accord, takes less than a minute actually.
it's in the faq now
Old Aug 5, 2006 | 06:20 AM
pumafeet10's Avatar
Default Re: SRS Reset (iam7head)
i did try the reset using the mes plug but the system wouldn't even respond so thats why i wanted to know if anyone else had this issue after replacing the cable reel or did it just resest it self after instalation? i have to get this fixed to get my car inspected thats why i need to have it taken care of.
Old Aug 5, 2006 | 06:57 AM
Honda-Master's Avatar
try this
http://www.hondaaccordforum.co...m.htm
and no, it will not reset by itself , make sure you plugged everything in , if it still will not reset , you need to read the code and post it here
Old Aug 5, 2006 | 02:39 PM
pumafeet10's Avatar
Default Re: SRS Reset (Honda-Master)
that is what i did and it didn't respond at all. Im sure the clock spring is working and getting power because all of my steering wheel mount acc. are working but i can't get the srs to go out. Now if i wanted to find out what the code was how do i go about doing that? Would i go thru the ecu or what. i know people do it all the time but i have never needed to since i have never had a cel so never had to use the trick? thanks
Old Aug 6, 2006 | 06:55 PM
pumafeet10's Avatar
anyone else ill be home tomorrow so that i can look at it again before i can get it inspected so i guess we will see hopefully no dealership fees!
Old Aug 8, 2006 | 05:40 AM
hondaccord's Avatar
Yeah just wanted to say that they did it for free, but I gusse it depends if the people are cool or not, because an *** might still charge you.
Old Aug 8, 2006 | 10:28 AM
pumafeet10's Avatar
see "what i heard " was that some people will charge and some won't! but the ting that im worried about is what if something else is messed up and then i have to pay more money to buy more parts and it just keeps going i jsut want it reset and to be done with it. I was just working on it and everything is hooked up and the sytem does not respond at all. i can't get the light to even blink so i don't know whats wrong with mes reset does not work.!!!!!! help!!!!
Old Aug 8, 2006 | 06:55 PM
pumafeet10's Avatar
so can anyone help me ever replaced their cable reel/ clockc srping and what happened after?the m e s plug reset is not working!!!! HELP ME!!!
Speed_1
Aug 16, 2007 06:32 PM
UNKNOWN_MEMBER
Oct 26, 2005 01:43 PM
klomast3r
Oct 6, 2005 03:11 PM
DAHUSKERS
Oct 18, 2004 11:56 AM
theman-dlh
Audio / Security / Video
Sep 5, 2003 06:36 AM
