WTB: B16A3 intake manifold
Old Aug 4, 2006 | 06:23 PM
WHAT TEH's Avatar
Default WTB: B16A3 intake manifold
WTB: B16A3 intake manifold. MUST BE B16A3 intake manifold. i need it per CA SMOG referee.
thank you!
_taF
Old Aug 5, 2006 | 09:13 PM
WHAT TEH's Avatar
Default Re: WTB: B16A3 intake manifold (tallazzFilipino)
bump
Old Aug 5, 2006 | 11:24 PM
WHAT TEH's Avatar
ttt
Old Aug 10, 2006 | 10:52 PM
WHAT TEH's Avatar
bump
Old Aug 10, 2006 | 11:26 PM
eg6sir88's Avatar
you can use a JDM p30 manifold if you tap the vacuum nipple on the far back side of the manifold, opposite of the throttle body
Old Aug 10, 2006 | 11:42 PM
egricepatrol's Avatar
i think i got one complete u need a obd2 right?
Old Aug 10, 2006 | 11:44 PM
eg6sir88's Avatar
he needs OBD1
Old Aug 14, 2006 | 12:16 PM
WHAT TEH's Avatar
Default Re: (eg6sir88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir88 &raquo;</TD></TR><TR><TD CLASS="quote">you can use a JDM p30 manifold if you tap the vacuum nipple on the far back side of the manifold, opposite of the throttle body</TD></TR></TABLE>
i have a JDM intake mani' on there right now. tha JDM intake mani's don't have tha vacuum port in tha back for tha EVAP purge solenoid cut-off valve (like USDM versions). only thing near tha back is tha larger gauge vacuum port for brake booster. there are 2 vacuum ports up front -- larger gauge one for PCV valve and smaller gauge one for fuel pressure regulator. i have a US-required EVAP purge cut-off solenoid valve t-tapped to tha vacuum port for tha fuel pressure regulator. accordin' to referee, that's a big "NO." vacuum lines (among others) must follow USDM version.
correct. OBD-I off B16A3, not A2. 99/00 A2's got rid of tha IAT sensor bein' on tha intake mani' runner. they relocated it to intake pipin'.
_taF
Old Aug 14, 2006 | 12:28 PM
eg6sir88's Avatar
thats what i'm saying.. on the far back side there is a small flat circular spot.. you can tap a hole into the mani. and put the nipple there for that vacuum line.. no need to tap into the FPR line.. i'll see if i can get a pic to show you.. it just has to look stock..
Old Aug 14, 2006 | 12:31 PM
eg6sir88's Avatar
this is on ebay
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Aug 14, 2006 | 12:37 PM
eg6sir88's Avatar
where it is circled in red you can tap a hole and put a nipple right the.. your manifold doesnt have that nipple there right??, thats why you had to t-tap the FPR line.. just trying to help you.. with a cheaper way of doing it.. i dont see why it wouldnt work.. they see p30 and all the emissions are hooked up and pass it..
Old Aug 14, 2006 | 04:05 PM
WHAT TEH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir88 &raquo;</TD></TR><TR><TD CLASS="quote">where it is circled in red you can tap a hole and put a nipple right the.. your manifold doesnt have that nipple there right??, thats why you had to t-tap the FPR line.. just trying to help you.. with a cheaper way of doing it.. i dont see why it wouldnt work.. they see p30 and all the emissions are hooked up and pass it..
yeah, i had all my emissions parts hooked up. i even passed SMOG. he said since tha vacuum lines didn't match that of tha USDM '95 Del Sol, he wouldn't pass it. i know ppl who have done this same shiet, and tha ref' guy they went to allowed it. as this ref' guy said: "there will be no t-tapping and i don't want to see you drill a hole there next time you come back."
my engine bay harness had corrosion from a battery that must have leaked fromt ha previous owner. before i dropped tha engine in, i removed all tha ugly black wire loom and reloomed it with see-through loom. he put down that my engine bay harness was modified and that i "may have to get a new one." -gay
_taF
Old Aug 14, 2006 | 05:02 PM
eg6sir88's Avatar
that sux.. did you see the ebay link
Old Aug 16, 2006 | 10:24 AM
WHAT TEH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir88 &raquo;</TD></TR><TR><TD CLASS="quote">that sux.. did you see the ebay link</TD></TR></TABLE>
no. what eBay link? where?
_taF
Old Aug 16, 2006 | 11:30 AM
eg6sir88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir88 &raquo;</TD></TR><TR><TD CLASS="quote">this is on ebay
http://cgi.ebay.com/ebaymotors...QrdZ1</TD></TR></TABLE>
this one htat nobody bid on.. you should message the guy and make him an offer
wow, that sux you didnt see it.. you coulda got it really cheap..
Blah.
Jun 26, 2010 12:41 PM
g2_teg_
Apr 5, 2009 10:14 AM
Westrock2000
26
Nov 5, 2007 04:15 AM
retroshark
Dec 23, 2006 09:54 PM
R_type
Jun 1, 2005 04:26 AM
