Vision one touch seat rails
Well after waiting a month for JHP to get these for me. I finally got these and installed them on my recaros. They lowered the seats nicely. But I haven't driven it like that yet. Oh I also know now why they call them one touch. You set them where you want them and thats where they stay. They don't like to slide at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01usjdmr »</TD></TR><TR><TD CLASS="quote">Oh I also know now why they call them one touch. You set them where you want them and thats where they stay. They don't like to slide at all.</TD></TR></TABLE>
Did you grease up the seat rails before installing them? When I received my rails from Vision, they didn't have any grease at all.
My seat rails slide as easily as stock.
do your vision sliders have only two mounting holes instead of the three holes per side on the original recaro railings? i was thinking this would make the seat flex more
First, I installed the bolts loosely. Then I tightened them and I had no problems.
They definately needed more grease I had to grease each side of the rails. Basically where it was metal to metal. Then they slided much easier.
What is the bolt hole spacing (seat bottom) on the Vision sliders?
I have a set of Sparco Milano seats with a Sparco/Wedge combo slider and I'm sitting higher than normal. Looking to lower myself and if these work they would be a simple fix. Sparco lists their bottom mount holes at 271mm x 345mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">hey dude can you compare how low your jdm recaros with the vision rails sit compared to stock us seats?</TD></TR></TABLE>
I've sat in both and don't have solid numbers to compare, but it is without a question much better (as in low).
Even stock JDM seat rails + Recaros make the USDM seat feel like a couch. Reid should know, the USDM ITR seats are actually put into the "Style-S" Integra (forget the exact name) or some automatic only girl spec Teg in Japan
Jer'rome
Honda Civic (2001 - 2005)
Mar 15, 2007 12:58 PM
01-0720
Jun 21, 2006 12:30 AM
