Need Help...Locating Transmission Drain Plug!?!?
can some one please post a picture of where the transmission drain plug is?
or atleast explain where its located...im going to do a drain and refill...
thank you...
thank you...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 »</TD></TR><TR><TD CLASS="quote">Passenger side like businessmanph said. Make sure to use a long handled ratchet...</TD></TR></TABLE>
bad idea actually, most people use a long rachet and turn it slowly, because the metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose</TD></TR></TABLE>
What metal to metal contact are you talking about? Not trying to sound dumb or nothing but I don't see what you're speaking of...
well...the drain and refill was a complete success...thanks to you guys for helping me out...the lug came out with one great big jolt...i used the regular size ratchet. came out like a champ. looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tech-Nics »</TD></TR><TR><TD CLASS="quote">... looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...</TD></TR></TABLE>Fill whatever amount makes the correct level on the dipstick. (Car warmed up, shift into park, turn OFF the engine.) Don't simply go by quarts. The tranny & torque converter have something like 7 or 8 quarts in there, but only 1/3 or 1/2 of it can drain out.
Peter_404_21
Dec 30, 2008 08:54 PM
gulftiresinc
13
Sep 28, 2004 06:23 AM
