P1259
Old Aug 4, 2006 | 12:55 PM
EK9KiNG's Avatar
Default P1259
00' Si throwin the VTEC malfunction code ....H E L P
Old Aug 4, 2006 | 12:56 PM
EK9KiNG's Avatar
Default Re: P1259 (EK9KiNG)
. . . . On h0w to fix>
Old Aug 4, 2006 | 12:58 PM
Miracle's Avatar
Its an oil switch I believe. The VTEC oil pressure switch is a normally closed switch. The ECM sends a voltage to the switch and expects the voltage to go through the switch to ground. If the ECM reads a voltage on that circuit when the VTEC system should not be operating, it will turn on the "check engine" light and set a code. This code will be a P1259 on a vehicle with OBD-II.
You can buy a new switch from http://www.hondaautomotiveparts.com for about 43 bucks.
http://www.hondaautomotivepart...83%29
Its number 15 on the diagram there.
Old Aug 4, 2006 | 01:10 PM
Miracle's Avatar
Default Re: P1259 (Red_EM2)
Replace the switch. Its as easy as that.
Old Aug 4, 2006 | 02:35 PM
EK9KiNG's Avatar
thanx bro.
lcommisso
Dec 10, 2018 09:13 AM
UDUBdriver
Engine Management and Tuning
Sep 4, 2011 07:04 AM
93 accord H22a
Jun 15, 2004 11:45 AM
slackeR1366
Dec 29, 2001 02:03 PM
slackeR1366
Dec 29, 2001 01:44 PM
