brakes lights
Old Aug 4, 2006 | 12:23 PM
db8geezer's Avatar
Default brakes lights
i got a problem with my integ its a 96 gsr...the brake lights dont work when i hit the brake pedal..its not the fuses or the bulbs i already checked them...the tail lights turn on when the parking lights are on so what can it be ?
Old Aug 4, 2006 | 03:39 PM
DirtyBirdJR's Avatar
Default Re: brakes lights (db8geezer)
is there power going to your brake lights (12v)? check your brake light switch.
Old Aug 4, 2006 | 06:36 PM
Kamikaze's Avatar
Default Re: brakes lights (DirtyBirdJR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyBirdJR &raquo;</TD></TR><TR><TD CLASS="quote">is there power going to your brake lights (12v)? check your brake light switch.</TD></TR></TABLE>
Look under the dash, look up above the brake pedal, you'll see a rubber piece on the back of the brake pedal (or if you're lucky you'll see rubber pieces down near your feet). Check the relays and fuses.
Old Aug 5, 2006 | 12:33 AM
calxtreme's Avatar
check the bulbs in the taillights. They are 1157 bulbs. Make sure the high filaments are not burned out.
Old Aug 5, 2006 | 02:27 AM
db8geezer's Avatar
Default Re: (calxtreme)
thanks for the help.. ill check it in the morning
Nathan_volcom
Jan 30, 2009 10:00 AM
Blackcat_78
Oct 20, 2007 12:20 PM
GSR-Street Racer
Jun 21, 2006 04:24 AM
slowassR
Sep 3, 2003 08:43 AM
HatchBeezy
Jun 11, 2003 10:26 PM
