Emergency! I need a response/help ASAP
I'm changing my breaks and rotors, i've already done the passenger side front. But when i went to do the driver side front I think the bottom caliper bolt threads are stripped on it and it just turns in the hole but doesn't come out. I have to leave for work at 2 p.m. and need to get this fixed asap. How do I get the bolt out?? Does this also mean the caliper hole is probably also stripped on the inside and i'll need either a new caliper or the hole re-drilled? This freakin' sucks.
my car is a 97 ex / no abs
i'm referring to the caliper bracket, or the part that you rotate up to get the pads out. thanks
gotcha...there should be a flat rectangular shaped washer on the other side of the caliper bracket that i had to hold with a pair of vice grips till i got the bolt loose. I have a 99 ex w/ no abs so im sure its the same situation. I thought i had striped it as well but once i looked in the bach and saw the flat rectangular shaped washer spinning with the bolt i clamped some vice grips on and vola came right off.
i am also wondering.. since it doesn't look like im gonna get this fixed before work if it is safe to drive my car with a "maybe" stripped caliper bolt and brand new rotor and pads on only one side of the front.... would this make things too un-even?
Yah that thing is spinning with the bolt so i'll try that right now.... i wonder why the other side didn't do this either. But thanks a lot man, i'll check back to update if it worked or not.
Future Reference: Unless you're delivering organs, no job is worth risking your life because your brakes aren't assembled correctly. I'm sure they'd understand if you called and explained.
Built B18ABorC
Sep 9, 2004 07:34 AM
pbcdb
23
Mar 14, 2004 02:51 PM
