FS: '93 Nissan Sentra SE-R in Omaha
<FONT SIZE="18">’93 Nissan Sentra SE-R</FONT>
5 spd, 155k miles on chassis, power sunroof, A/C, tilt, cruise
Cali car NO RUST through
Low mileage UK SR20DE swapped with less than 35k miles (2.0L)
which came out of a Nissan Primera with 10:1 CR
<u>All parts purchased BRAND NEW and installed (less than 10k miles)</u>
ACT HDSS Clutch kit, resurfaced flywheel
Cobalt Friction rotors, Axxis Ultimate pads all around, ATE Super Blue fluid
Hotshot intake
HKS Sport exhaust
OBX header, OBX high flow cat
Progress LCA brace and rear sway bar
New radiator
New Front lower balljoints (both sides)
New high pressure power steering hose
New fuel filter, plugs, plug wires
Custom powdercoated valve cover
Lightweight battery relocated to trunk and custom mounted
CV joints/axles
Comes with stock SE-R wheels
<u>The GOOD</u>
This car runs hard and is quick for what it is. Strong, high compression SR20DE.
NO RUST, Cali car (minor surface rust here and there)
No 5th gear pop out
Clean interior
Good gas mileage…24-26 mpg city
Factory LSD
Somewhat rare with a lot of aftermarket support (parts cost less than Honda)
<u>The BAD</u>
Minor dings/dents
Needs a paintjob (paint fading and flaking)
Needs the old crappy, bubbled tint stripped off rear windows
A/C doesn’t work (needs recharged)
Power sunroof doesn’t work
Windshield has a crack (not spiderweb, ie doesn’t obstruct view too much)
Power steering rack has a minor leak
There are probably parts I’m forgetting to list. I’m not listing this car because I have to sell it. I’m just testing the waters at this point, but if it sells then fine. I had a lot of plans to race this, but I really can’t afford to finish it the way I want. I've only AutoX'd it one time.
Asking <FONT COLOR="blue">$3300 obo</FONT>
PLEASE...no lowballers or tire kickers. If you're not interested, don't reply. I know what KBB and NADA have listed. This car has a fresh engine and many new parts. It doesn't run like a 13 yr old car whatsoever. Function over form. I don't half *** things so I didn't cut corners with the swap.
Car DOES NOT come with the wheels in the pics, but I will include them for more. It will have the factory SE-R wheels.
Hotshot intake
HKS Sport exhaust
New radiator
CV joints/axles
<u>The GOOD</u>
No 5th gear pop out
Clean interior
Factory LSD
<u>The BAD</u>
Minor dings/dents
Yellow Dragon
Aug 5, 2006 08:36 AM
