oem belt tensioner fit for all?
sounds like you need to tighten it more, stock torque spec is 40 foot pounds
if you recently did a timing belt on your car it could be the belt is strecthing out
but I would re-tension it and torque it to 40 ft/lbs and see if the problems repeats itself
