spoon/mugen headgasket worth it?
Old Apr 23, 2002 | 10:45 PM
comptechgsr's Avatar
Default spoon/mugen headgasket worth it?
im gonna have to reinstall my toda b's after i get carb ref'd./....
so r they worth it in a stock CR b18c1?
Old Apr 24, 2002 | 04:43 AM
Mike K's Avatar
Default Re: spoon/mugen headgasket worth it? (comptechgsr)
No. But a milled head and/or thin OEM headgasket is worth it, for sure.
Old Apr 24, 2002 | 07:26 AM
iperez's Avatar
I have a Spoon 2-ply on my B18C5 with OEM pistons and head. The difference is really not noticeable. On the other hand, if you need to replace your head gasket due to some other type of work on the car anyway, you might as well go with a 2-ply or even a 1-ply. The CR increase is definitely there just not as feelable as you may expect. I guess it will be more obvious when I add more parts (cams, head work, etc.). The gasket's quality is good and the seal is perfect as you may expect from Spoon.
Old Apr 24, 2002 | 07:40 AM
Default Re: spoon/mugen headgasket worth it? (iperez)
would it be possible to put on an itr head gasket?
what CR would that yield?
Old Apr 24, 2002 | 09:40 AM
Mike K's Avatar
ITR and GSR share the same headgasket, as does the B16/B17.
Old Apr 24, 2002 | 09:58 AM
GraphiteAccord's Avatar
Default Re: spoon/mugen headgasket worth it? (Mike K)
Mike k, any experience doing this with the H22a head gasket?
Old Apr 24, 2002 | 10:02 AM
RyanR's Avatar
Just pull of the copper rivets and toss the middle layer in the trash and use the top and bottom layer. Worked great for me on my B16a.
Old Apr 24, 2002 | 11:08 AM
vpc's Avatar
vpc
New User
Default Re: spoon/mugen headgasket worth it? (RyanR)
i did the same on my Si...bumped it up around .2 and i can definitely feel a small difference.
btw...here's a good compression calc
http://www.c-speedracing.com/howto/c.../compcalc.html
[Modified by vpc, 12:09 PM 4/24/2002]
Old Apr 24, 2002 | 11:36 AM
STOLEN - ITR 98-0652's Avatar
If you're pulling the head (just to replace a gasket) and you really want to increase CR, save your pennies and do it right - PISTONS.
Milling the head or decking the block do it, too... but it is a one way street and it is a consequence of the procedure more than its purpose. Milling/decking is done to correct warpage and true the head/block, but as a consequence of removing materieal, you raise CR.
High Compression pistons may be more expensive and more involved, but it's the best way to raise CR.
Old Apr 24, 2002 | 11:47 AM
AJ PwR's Avatar
Spoon head gaskets are manufacture by race division of Honda. The 2P head gasket offers 1 thinner layer and 1 thicker layer. This design to provide better sealing and eliminate vibration between head and block during high rpm. Quality is definitely over stock and IMO is definitely worth it.
HiChanDC2R
Aug 31, 2010 08:28 AM
OldSkoolDA
Sep 25, 2005 02:26 PM
grenthang
Jul 13, 2004 01:57 PM
snake01
Nov 13, 2002 03:26 PM
Edwin
Jul 11, 2002 11:11 PM
