Bearings
Old Aug 3, 2006 | 09:25 PM
solid gsr's Avatar
Default Bearings
I am building an B20/Vtec and i'm replacing the bearings, should I go oem or aftermarket? Also if i go oem is there a difference with the b18's/b20's?
I'm going to be running the stock B20B crank and pistons.
Old Aug 4, 2006 | 03:26 AM
non-VTEC's Avatar
Default Re: Bearings (solid gsr)
OEM bearings
Old Aug 4, 2006 | 08:52 AM
doublejz's Avatar
Default Re: Bearings (non-VTEC)
Most people will say OEM since you can get the exact clearance you need. I've always used ACL and never had a problem tho.
spoolinvtec54
Nov 13, 2011 09:06 AM
golf-mk3
May 11, 2010 01:37 PM
ProjectGSRHatch
Jan 21, 2005 07:16 PM
eddiecut
29
Nov 23, 2003 01:44 PM
