Kamikaze's Integra Light Problem...
Old Aug 3, 2006 | 08:50 PM
Kamikaze's Avatar
Default Kamikaze's Integra Light Problem...
Sup guys? I've been having this problem for a while, where my outter front bumper light and tail light don't come on. I went to Acura but they were going to charge me $88.00 an hour to just find the "problem" but after waiting 3 hrs of my hazard lights sitting on and not even being taken to the back I left. So I'm stuck with this light problem, it's not that it's a problem but it's a safety precaution, opposite lanes can't see me coming over unless they are some feet ahead or behind. Here's a pic of my teg with the light out.
It's the same side on the back, the lil triangular light on the rear right corner (closest to passenger side)
Any help?
Old Aug 3, 2006 | 09:15 PM
StolenTeg's Avatar
Default Re: Kamikaze's Integra Light Problem... (Kamikaze)
There suppose to be a bulb there
dFreezy's Avatar
i take it you've replaced the outer bulb and checked the fuse?
Old Aug 3, 2006 | 09:16 PM
Kamikaze's Avatar
There is a bulb there, just doesn't illuminate...
Kamikaze's Avatar
Yep, but doesn't that fuse control, the whole front bumper light, and not just one? And why would only the right side go?
Old Aug 3, 2006 | 09:25 PM
bokals's Avatar
Default Re: (Kamikaze)
have you checked the wires? anyways whys this in apperance? not to be a dick or anything
but check the wires and fuses, if that doesnt work, try another blub?
Old Aug 3, 2006 | 09:27 PM
Kamikaze's Avatar
Tried replacing the rear and front bulbs, still nothing, I thought it would be in appearance/cosmetics because it has something to do with the appearance of the car??? Lol, guess it could go in tech...Meh...
Old Aug 3, 2006 | 09:31 PM
sittingonROTAS's Avatar
76.216.10.150
yea check the wires and harnesses. make sure everythings legit. and if that doesnt work do a 98+ conversion and buy my turn signals off me.
Old Aug 3, 2006 | 09:33 PM
Kamikaze's Avatar
Getting some all reds already, but the thing is, this happened even before I put my 94-97's back on... So i'm going to be buying some all reds, and I think I'm going to put on the new wiring harness... I'll try the new wiring for the rear end that I got with some tail lights.
Old Aug 4, 2006 | 07:29 AM
HONDA RR's Avatar
There should be a bulb there try to replace it maybe its out or missing. It thats not the problem then check the wiring harness its all plug and play.
Old Aug 4, 2006 | 06:11 PM
Kamikaze's Avatar
Yeah I've already replaced the bulbs, done everything but check the relays, really a noob on that... also been checking fuses but it seems like they are pretty stuck in place. Any help? Even using the fuse grips...
Old Aug 4, 2006 | 06:37 PM
StolenTeg's Avatar
The socket for the bulb might be bad, you can buy it at the dealer for like 12 buck
Old Aug 4, 2006 | 07:06 PM
DC4KiD's Avatar
Default Re: (StolenTeg)
I dunno but those 194 bulbs are notoriously known to blow out very fast... especially after u take em off and put them back in... at least with my experience.
When u install your next bulb, make sure to clean it off real good to get any skin oil off.
Old Aug 4, 2006 | 07:35 PM
Kamikaze's Avatar
Yeah, I wiped the other grime and crap out and made sure not to touch the bulbs themselves.
justhatched231
Aug 31, 2010 06:57 AM
jlow125
Aug 31, 2008 03:48 PM
