Need help with dizzy issue
Old Aug 3, 2006 | 06:03 PM
eye.ha8.u's Avatar
Default Need help with dizzy issue NEED HELP FAST!
I put a POS dizzy in a little over a month ago to get me back to kansas and it got me here but just recently went out. So I got a new, good one. I put it in, and at first I did screw up the firing order, but that is fixed, but it still wont start, while I am turning the key if I press the gas it makes a boom bump sound, lol cant explain it... everything is freaking new cap, rotor... etc. NEED HELP ASAP!
Thanks
Modified by JayDeeEmm at 8:22 PM 8/3/2006
Old Aug 3, 2006 | 06:25 PM
eye.ha8.u's Avatar
Default Re: Need help with dizzy issue (JayDeeEmm)
Just to add, when it originally went out, It did just go out like that, the car would shut off and not start then eventually would turn on agian for a little while etc. Then when I put the other dizzy in it was fine, well this time it was doing the exact same thing, which I had a feeling cuz that dizzy was a POS too. Yesterday I got it to start hit the gas went up like **** and shut off. Now I switched it wont start at all, and while its trying to crank I can hear air coming out of my exhaust, and when I hit the gas it makes a sound too, what the hell did I do wrong? I got the dizzy from dizzy king.
Old Aug 3, 2006 | 07:23 PM
eye.ha8.u's Avatar
anyone??? trying to fix tonight
Old Aug 3, 2006 | 11:28 PM
theinfamouskonrad's Avatar
Are you sure it's a spark problem? Make sure your getting fuel.
Old Aug 4, 2006 | 01:33 AM
eye.ha8.u's Avatar
Default Re: Need help with dizzy issue (theinfamouskonrad)
Like 99.99999%sure... You can hear a difference with the car trying to start since I swaped over. Something isnt right.
Old Aug 4, 2006 | 03:09 PM
eye.ha8.u's Avatar
I'm going mad, I am positive its not a fuel issue and its not the main relay.
Old Aug 4, 2006 | 08:35 PM
89hybrid's Avatar
I had same problem well sort of. I believe this advice should help. Try advancing the wires on the cap or retarding them. Good luck.
Old Aug 4, 2006 | 08:37 PM
Hamstr323's Avatar
Default Re: Need help with dizzy issue (89hybrid)
are you sure the firing order is right?
Old Aug 6, 2006 | 10:52 PM
89hybrid's Avatar
Default Re: Need help with dizzy issue (Hamstr323)
I know it doen't make sense. Just try it maybe it will work for you.
Old Aug 7, 2006 | 07:43 AM
Duane_in_Japan's Avatar
We would like verification on fuel pressure and spark please, timing is next and compression. Then what you think, spark strength.
Old Aug 8, 2006 | 08:20 PM
gp70hs's Avatar
Default Re: Need help with dizzy issue (Duane_in_Japan)
Are you sure that when you put the new dizzy in that you had it oriented correctly. The pin on the end is offset just a small amount to one side. It is possible to put it in backwards, which means the wiring doesn't match the engine.
Old Aug 9, 2006 | 11:11 AM
2fast4udude's Avatar
Default Re: Need help with dizzy issue (gp70hs)
99% positive your firing order is incorrect.
Old Aug 9, 2006 | 12:09 PM
eye.ha8.u's Avatar
Default Re: Need help with dizzy issue (2fast4udude)
I'm 100% sure it is correct, I finally got all the "right" tools, going to check fuel pressure, compression etc. today. I havent had time the past few days, I'll know the issue in a few hours.
Old Aug 9, 2006 | 05:26 PM
eye.ha8.u's Avatar
Ok, did the timing and checks the valves, they were loose.
Problem solve car runs good, thanks for all your help.
jasonlunaa
May 28, 2014 09:06 AM
vtak2nr
Mar 8, 2007 04:23 PM
Tr0LL
Nov 5, 2006 12:20 PM
xkagax
13
Feb 22, 2006 05:47 AM
GOLDBERG
Mar 21, 2003 01:49 AM
