93 accord brake question
Old Aug 3, 2006 | 11:50 AM
cincispeedemon's Avatar
Default 93 accord brake question
I was told that I need to have a special machine to get the rotors off, is this true???
Old Aug 3, 2006 | 03:10 PM
Default Re: 93 accord brake question (cincispeedemon)
bump
Old Aug 3, 2006 | 03:56 PM
Honda-Master's Avatar
go to
http://www.hondaaccordforum.com
go to the DIY section, there is a step by step write up on how to replace rotors
Old Aug 3, 2006 | 04:44 PM
BluLude's Avatar
some years have ones that are apart of the wheel hub, you will need a slide hammer to pull the hub off...i wouldn't change them if you didn't have to, the time it takes to pull one out is preety much a toss up, I have seen 5 minutes and I have seen 5 hours.
Old Aug 4, 2006 | 05:48 AM
Hwj_33's Avatar
Default Re: 93 accord brake question (Hwj_33)
I worked on those rotors bofore and what I did was use a big socket that will fit in the inside of the hub bearing and pound it out with a hammer. Works when I do that.
Jetro
Jan 7, 2011 12:19 PM
LandHard
Aug 12, 2009 07:25 AM
Joetravelall
Feb 20, 2007 03:25 AM
Stealthman80
Oct 3, 2005 08:07 AM
briq4
May 1, 2004 06:56 AM
