Help Ek bezel install
it a pretty simple process...first you will have to take out your black trim, that trim has 2 screws that is on the top, and has 2 metal clips at the bottom, be very careful it break really easy. once the plastic trim is out you will see 4 screws holding your cluster down. once you have those 4 screws out, you will have to take out the plug from the back of the cluster...there are 2 plug here...be careful as well it maybe tough if you havent open it before...i want to say one green clip and one light blue clip...once the cluster is out...you will see a clear plastic cover for the gauge cluster, which i want to say it has 6 or 8 clip all clear so you cant miss it... once that is out you will see the bezel...you pull that out and replace it with your CTR, and put everything back in the oppisite order... i hope this help
sorry i am going off by memory, if i miss anything please fill in guys
jdmpower363
Feb 24, 2009 09:01 PM
SilverGT
Dec 8, 2006 09:52 AM
allicedout
Aug 26, 2003 03:39 PM
