Results of what I've been up to the past eight months. (Image intensive)
213 whp 171 ft/lbs @ 10psi
1999 DX hatchback
Stock y7 block, stock y8 head, y8 intake mani, z6 tranny
T3 .60 / .48
Spoolin AC log, AC 2.5" dp, closed-loop dump tube
Tial 38mm wg
1g dsm bov
Stealthmode oil feed/return
2.5" ic piping
CCA 6" fmic
dsm 450's
Walbro 255lph
Joe P. mbc
GE vac mani
2.5" exhaust, carsound cat, 22" resonator, magnaflow oval
ACT XTSS clutch
ARP head studs
p28 w/ crome
Street tuned by David Lee
Modified by EK k kay at 12:04 PM 8/3/2006
Modified by EK k kay at 9:31 PM 10/31/2006
1999 DX hatchback
T3 .60 / .48
Tial 38mm wg
1g dsm bov
2.5" ic piping
CCA 6" fmic
dsm 450's
Walbro 255lph
Joe P. mbc
GE vac mani
ACT XTSS clutch
ARP head studs
p28 w/ crome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch »</TD></TR><TR><TD CLASS="quote">SUPER CLEAN SETUP
great to see another turbo d
</TD></TR></TABLE>great to see another turbo d
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 »</TD></TR><TR><TD CLASS="quote">if your ac still works, you are true gangsta. good job
Works and blows just as cold as it used to. Theres a 12" 2100cfm fan mounted as a pusher.
</TD></TR></TABLE>Works and blows just as cold as it used to. Theres a 12" 2100cfm fan mounted as a pusher.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">overall, its very nice.
nice setup
i would push more than 10psi tho.
Yeah I'm surprised that the top end is still pulling. Maybe in the future I'll up the boost to 12lbs. I know I'm making more than 213whp because the dyno only shows it going to around 6700. It's got about 500rpms to go. It should hit the top of that graph.
nice setup
</TD></TR></TABLE>Yeah I'm surprised that the top end is still pulling. Maybe in the future I'll up the boost to 12lbs. I know I'm making more than 213whp because the dyno only shows it going to around 6700. It's got about 500rpms to go. It should hit the top of that graph.
