brake help ASAP
Old Aug 3, 2006 | 10:42 AM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default brake help ASAP
hey guys, quick question. today i was changing my pads and rotors and while pulling the wheels off, i broke a hub stud. i have gotten the broken one out and went and picked up a new one.
im not positive how to put it back on though, since it doesn't fit due to the shield blocking my way. do i have to pull the hub off to change it? it seems like there is an easier way. i know this sounds extremely ghetto, but what about drilling a hole big enough in the back of the brake shield to slip in the stud?
well, let me know what you guys think. this is the last thing i need to do, other side is all finished
Old Aug 3, 2006 | 10:47 AM
rino924's Avatar
Community Builder
Default Re: brake help ASAP (rino924)
doh! searching ownz me. here is the thread below, and mods, if there is any way, can we geth this thread put into the FAQ stickied at the top of the page in the brake section?
oh, the archived search of honda-tech = amazing
thread here:
https://honda-tech.com/zerothread?id=996341
Old Aug 3, 2006 | 11:27 AM
rino924's Avatar
Community Builder
well, it didn't work
i really don't wanna pull the hub off, so any help would be great
i might just drill through the dust shield
Old Aug 3, 2006 | 11:34 AM
1GreyTeg's Avatar
Although I've broken a stud off before I had someone replace it for me so I can't walk you through the process, hopefully someone else can.
BUT I'd just remove the dust shield altogether anyway. So if that's all that's holding you up just take it off and install the bolt.
Old Aug 3, 2006 | 11:44 AM
rino924's Avatar
Community Builder
Default Re: brake help ASAP (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Although I've broken a stud off before I had someone replace it for me so I can't walk you through the process, hopefully someone else can.
BUT I'd just remove the dust shield altogether anyway. So if that's all that's holding you up just take it off and install the bolt.</TD></TR></TABLE>
yeah, i might, but it still doesn't look like it will clear
i think im gonna try it. every diagram and manual i have looked at have said that you need an axle puller in order to pull off the hub. even if i had one, i dont think i could pull it off because i already have the caliper and rotor off, and the car has to be sitting on the ground w/ wheel on and you have to go through the center cap so the whole assembly doesn't spin.
Old Aug 3, 2006 | 11:45 AM
rino924's Avatar
Community Builder
i bought two studs, in case i messed up another one (which i did).
i took the advice from the thread that I posted and when you hammer it through, it just strips off the threads and i really don't know how that dude did that. he said it was easy.
JDM Dylan
10
Mar 9, 2008 05:31 PM
del_sol
Feb 28, 2003 12:06 PM
A.D.R
Dec 5, 2002 04:36 PM
