Turbo charge a single cam??
Old Apr 23, 2002 | 08:31 PM
LS AnGeL's Avatar
Default Turbo charge a single cam??
yea I juss wanted to knoe if it is a good idea to turbo charge a single cam. Pleez help, da motor is a D17A2
Old Apr 23, 2002 | 08:33 PM
-Gambit-'s Avatar
Default Re: Turbo charge a single cam?? (Sp00nEK9)
i would do it, but most people on this site are going to tell you to just do a swap. But i believe in the single overhead cam
Old Apr 23, 2002 | 08:42 PM
Kamin's Avatar
Default Re: Turbo charge a single cam?? (ek9hatch)
the sohc is a good motor but for what your gonna spend on a turbo kit you could easialy drop a b18c in there and make comparable power.
the swap is easier and more reliable.
Old Apr 23, 2002 | 09:47 PM
bretx0r's Avatar
turboin the old D16 is a bigger bang for your buck then a swap, but a swap has more potential. but then again... you could turbo the SOHC for now... and when you get a swap... just change the manifold and tap the oil pan on the new one and whammo turbo swap
Old Apr 23, 2002 | 10:14 PM
GokuSSJ4's Avatar
Default Re: Turbo charge a single cam?? (bretx0r)
well it depends , you can achieve up to 175whp .seen the dyno on a turbo SOHC a while ago . but remember that will be the max hp out of the motor (in to reliable issues come in place) but the gains with the swap is that, the swap is just the beginning .b18c1 stock put out around 150-153whp ( i said around cause there are exepections) and from there you could decide N/A or Turbo . depending on your budget . but you can have lots of fun with just the swap and take it from there , seeing what you budget allows you
Old Apr 23, 2002 | 11:31 PM
RoaringTurtle's Avatar
New User
Default Re: Turbo charge a single cam?? (Spoon1)
i went the sohc turbo route
and im happy with my choice
my plans are to boost up to 12 psi with a vtec head
hopefully i can make around 215 whp or so
and thats some good power for a sohc
especially if your on a budget like me
[Modified by RoaringTurtle, 8:31 AM 4/24/2002]
Old Apr 24, 2002 | 12:55 AM
PyroVTEC's Avatar
New User
Default Re: Turbo charge a single cam?? (RoaringTurtle)
215whp on a D16 with a stock bottom-end? It's a matter of time before something breaks. D16 rods=dinky.
Not sure how easy it is to turbo a D17A2. I don't think anyone's made a kit yet for the 7th gen Civics.
Besides, a B-series motor wouldn't even fit under the hood of a Civic. You wanna swap? Try the motor/tranny from the RSX Type-S (F20B??? or is that for the S2000...hmmm...)
My rebuilt SOHC D16Y8 is currently underway. With the forged internals, I'm expecting 225whp daily.
Old Apr 24, 2002 | 01:16 AM
AJR EJ8's Avatar
Default Re: Turbo charge a single cam?? (PyroVTEC)
my friend did a 13.6 in the 1/4 in his turbo sohc del sol
Old Apr 24, 2002 | 01:50 AM
D16Z6racing's Avatar
Default Re: Turbo charge a single cam?? (TYPE ONE Si)
I'm boosting my d16z6. I've always had a single cam and loved it. Had 4 so far. 3 in my eg cx h/b and 1 in my crx si. I know my motor so well and it so easy to get a lot more power out of it.
Old Apr 24, 2002 | 02:32 AM
New User
nah not a stock bottom end
i would upgrade the pistons and rods when i put on the vtec head
Old Apr 24, 2002 | 02:58 AM
dirtySOHC's's Avatar
i cant get over your numbers your boosted SOHC makes especially your tq numbers. and it aint even a y8. i am gonna have to get up wit you on your set-up in the near future. i drive an ex coupe and i am saving up for a turbo also. i was saving for a swap but i said **** it and just get a turbo. if i blow the motor i can get a long block for cheap.
when you posted those pics of your ride when you painted your gsr's, that is when i got inspired to go the turbo route..........
Old Apr 24, 2002 | 03:25 AM
TurbodCX's Avatar
Default Re: Turbo charge a single cam?? (dirtySOHC's)
go with the single cam!!!!! i did and i love it, i laid down 229WHP and 190Ftlbs. of torque @ 12psi and it is awesome!!
STAY WITH THE SOHC
Old Apr 24, 2002 | 06:02 AM
DevinW's Avatar
I really like your car Roaring Turtle! It's cool to see someone turbo the d16y7...I was going to buy a 92-95 Si and turbo that..but instead i'm buying a cheaper car and swapping...to each his own...I'd be happy with either route though! I like the idea of turboing SOHCs because it's more original.
Old Apr 24, 2002 | 06:03 AM
DevinW's Avatar
Default Re: Turbo charge a single cam?? (TurbodCX)
TurboedCX..those are some fuggin sweet numbers you're getting out of your SOHC!
Old Apr 24, 2002 | 06:31 AM
TurbodCX's Avatar
Default Re: Turbo charge a single cam?? (DevinW)
thanks alot man, i am more than likely laying down more right now because i am at 16 psi and i did those other numbers at only 12psi.... so let the fun begin.
@ 16 psi i have nothing but wheel spin through the first two gears and half way through third I LOVE IT!!!
SOHC ALL THE WAY!!!!!!!!!!!!!!!
Old Apr 24, 2002 | 07:01 AM
TurboSedan's Avatar
New User
I just turbocharged my D16Y8. I run 9psi daily on the stock bottom end with a Hondata Stage 2B and RC440cc injectors. It pulls harder than my friends new WRX.
Old Apr 24, 2002 | 07:14 AM
tararan's Avatar
Default Re: Turbo charge a single cam?? (97CivicFerio)
i got my 00ex turbo'd with the greddy kit... im very happy with it.. and im still using stock boost too.. can't wait to boost more later on...
Old Apr 24, 2002 | 07:50 AM
OPTIMUS's Avatar
New User
Default Re: Turbo charge a single cam?? (tararan)
I am really glad to see so many positive comments about the SOHC on this post here.
Just because there are swaps available for the civics doesn't mean that you must go that route or if you even want to go that route.
I feel that any motor w/ stock stock internals under too much boost with blow.
Upgrade accordingly and have fun boostin.
Don't knock the SOHC cuz is missing a cam.
Also, not everybody want to drive a full drag car on a daily basis. If the GReddy turbo kit for the SOHC satisfied the driver then let him have the turbo kit.
KEEP BOOSTIN
Old Apr 24, 2002 | 07:59 AM
Pat McGroin's Avatar
Default Re: Turbo charge a single cam?? (OPTIMUS)
sohc is all good but a dohc is definitely better, and if you turbo a b18 or b16 then you got a hell fast car there
Old Apr 24, 2002 | 08:16 AM
gshockbreaker's Avatar
Default Re: Turbo charge a single cam?? (JDM Dasilva)
I drive a 2001 Civic... I know there aren't any turbo kits out there for my car right now, so should I just try to build my bottom end so when I get my turbo kit, I can boost the PSI to like 12lbs? Or just wait for the turbo and do the bottom end later?
Old Apr 24, 2002 | 09:54 AM
brcivic411's Avatar
true but then you're that much more in debt. you need to decide what your plans are. if you want a crazy hp monster, you may want to get a swap and then save for FI. if you're just looking for a little bit of fun on a lower budget, definitely turbo the sohc.
Old Apr 24, 2002 | 09:56 AM
DragII's Avatar
My Sohc was turbo'd for a lil over a year before I swapped the motor..then turbo'd that....SOHC turbo is lots of fun...but DOHC turbo is Even better
Old Apr 24, 2002 | 09:59 AM
95civiccoupe31's Avatar
Default Re: Turbo charge a single cam?? (SuperDragII)
I have D16Z6 and if i turbo high boost....i have to change rods, and pistons, but what about bal and blueprint? What is that for????
Old Apr 24, 2002 | 10:03 AM
DragII's Avatar
Default Re: Turbo charge a single cam?? (95civiccoupe31)
bal & blue print is basically making everything in your bottom end EXACTLY to spec...all gaps, torque specs, wear marks....everything is balanced, and installed to precise spec...
is it necissary....No
is it a good thing...definately.
Old Apr 24, 2002 | 02:58 PM
LS AnGeL's Avatar
so ur sayin any B-series motor wont fit on mai 2002 civic?
