94 Accord radio and door indicator problem please help.
Old Aug 3, 2006 | 10:26 AM
Gyoung145's Avatar
Default 94 Accord radio and door indicator problem please help.
Okay I got a 94 Accord, heres the deal when I start the car everything is fine until i turn on the radio. I get no sound however when I open and reclose the front passenger side door i get sound but the door indicator is now on and dim. It flashes with the beat of the radio and then when the radio is off the indicator works fine whether the door is open or closed. Please help?
Old Aug 3, 2006 | 04:52 PM
BluLude's Avatar
Default Re: 94 Accord radio and door indicator problem please help. (Gyoung145)
I would think that some wires are cut and are touching each other, if you open the passenger side door and look at where the hinges are, there will be some wires inside some black insulation that goes from the door into the car, (I'm really blanking out and not knowing what anything is called so bear with me), if you open it up you might fight your problem in there...either that or let a mechanic fix it
DFH
Nov 23, 2014 05:32 PM
bobby9523
Mar 19, 2013 11:01 AM
EgK2o09
Apr 10, 2008 07:54 PM
poly35
Sep 22, 2004 09:08 AM
