94 si rear to 92 dx (drum to disc)
Old Aug 3, 2006 | 09:52 AM
Fatty_1775's Avatar
Default 94 si rear to 92 dx (drum to disc)
Since its the same body, do i need the mc, brake booster or proportioning valve still? Or are they the same parts? Thanks.
Modified by Fatty_1775 at 7:15 PM 8/3/2006
Old Aug 3, 2006 | 09:53 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: 94 si rear to 92 dx (Fatty_1775)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">Since its the same body, do i need the mc, brake booster or pp still? Or are they the same parts? Thanks.</TD></TR></TABLE>
They are not the same and it is highly recommended to upgrade the rest as well.
Old Aug 3, 2006 | 10:00 AM
philosofy1's Avatar
Default Re: 94 si rear to 92 dx (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
They are not the same and it is highly recommended to upgrade the rest as well.</TD></TR></TABLE>
Old Aug 3, 2006 | 10:14 AM
Fatty_1775's Avatar
Default Re: 94 si rear to 92 dx (philosofy1)
part numbers are the same for both for brake booster and master cylinder on http://www.autopartswarehouse.com/ , maybe just swap the proportioning valve?
Old Aug 3, 2006 | 10:20 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fatty_1775 &raquo;</TD></TR><TR><TD CLASS="quote">part numbers are the same for both for brake booster and master cylinder on http://www.autopartswarehouse.com/ , maybe just swap the proportioning valve?</TD></TR></TABLE>
The proportion valve is the most important. I'm pretty sure you can get away with the 15/16 MC but usually people upgrade to the 91 Ex sedan MC b/c its 1" and it fits onto the stock booster
Old Aug 3, 2006 | 10:36 AM
Fatty_1775's Avatar
where is the proportioning valve located?
Old Aug 3, 2006 | 10:38 AM
cute little bastard
on the firewall. follow some of the brake lines from the MC towards the center on the car and you'll see it
Old Oct 17, 2006 | 09:09 AM
Fatty_1775's Avatar
so i got someone to do the swap. he used 95 integra brake booster, master cylinder and proportioning valve. today i just noticed that my ebrake is not working but i feel tension on the ebrake handle. if i got someone to press on the brake, would i be actually be able to see the caliper move? i want to know if its just the parking brake cable not working. thanks.
Old Oct 17, 2006 | 09:34 AM
instructor74's Avatar
It could be a seized rear caliper or a bad ebrake cable. disconnect the ebrake cable from the caliper and pull the brake handle have a friend look to see if the ends you disconnected move do this to both sides. If they do then they are ok and the caliper has a problem.
ViSiONxBoY
Mar 6, 2008 06:25 PM
tobe1424
Suspension & Brakes
Jun 20, 2006 09:11 PM
Gump
Feb 23, 2006 10:33 PM
tomaseuro
Oct 17, 2005 02:05 PM
