headlight housing
Old Aug 3, 2006 | 09:05 AM
Turbo_honda's Avatar
Default headlight housing
I wanna paint the headlight housing black to make it kinda look like the ctr. how do you get the housing off the headlight assembly? been trying at it for hours, im sure there is a thread somewhere but not good at the searching archives thing. so if someone would please help that would be awesome..
Old Aug 3, 2006 | 09:09 AM
someone please help
freakin_eLRoD's Avatar
Default Re: (Turbo_honda)
here you go https://honda-tech.com/zerothread?id=282131 took 2 seconds
Old Aug 3, 2006 | 09:11 AM
thanks.. how do you search archives. i cant ever do it right. to get the post i want.
Old Aug 3, 2006 | 12:14 PM
eddie_ek's Avatar
Default Re: headlight housing (Turbo_honda)
I do this all the time I use a heat gun and a screw driver but I found an easier way to do it I pre heat the oven for 20min at 375 the turn it off and put the headlight assembly inside the oven in a pan or something not right on top of the grill it will melt its plastic leave it inside for about 5min use your judgement then take it out and start splitting the assembly open the glue should be nice and soft make sure to clean the glue out so you dont have any leaks when putting back together make sure to use water proof silicone.After you split the housing apart remove the chrome besel 2 phillips bolt hold it in. make sure to sand the chrome besel with a scuff pad and I painted mine satin black and looks good I even painted the grey housing flat black looks good too good luck with the project
Old Aug 3, 2006 | 12:16 PM
Sean @ ESG's Avatar
pop it in your easy bake oven
Old Aug 3, 2006 | 02:18 PM
Got it done thanks for all the help, they look good.
crxaddikt
Nov 3, 2013 10:28 AM
8dxhatchy8
17
Feb 17, 2009 07:16 PM
d1nki
Apr 27, 2006 08:26 AM
HaRrYbOy
Honda Motorcycles
Jan 2, 2006 09:45 PM
98civicR
12
Nov 4, 2002 06:10 PM
