DIY Timing Belt and Water Pump
Old Aug 3, 2006 | 05:00 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default DIY Timing Belt and Water Pump
I was just wondering if there was anywhere on the internet or on this forum where there was detailed instructions on how to change your timing belt and water pump. I already have all of the parts I just need to put them in. Or would it be easier just to take it to a mechanic? How much would they charge?
Old Aug 3, 2006 | 05:17 AM
Racermech's Avatar
Default Re: DIY Timing Belt and Water Pump (SupersonicBlueGSR)
How good are you with tools?? I jsut did mine, it is not hard, just time consuming and some of the bolts are a bit hard to get to.
The worst part was getting the crank pulley bolt off. That was untill I got my compressor and gun, then it came right off.
Old Aug 3, 2006 | 06:48 AM
S2KILLA's Avatar
Default Re: DIY Timing Belt and Water Pump (Racermech)
how much time and effort are we talking about, i have plenty of tools, just dont want to expletive up the timing thats all, id prolly feel better by taking it to a professional, how much we talking just for the labor?
Old Aug 3, 2006 | 07:45 AM
BLacK FirE's Avatar
Firgure around $500 to have someone do it. I just did mine too. As racermech it is a bit time consuming if its your first time. I could probably do it now under 2 hours. Also as he said the crank pulley bolt is going to be the hardest to do. I suggest not starting until you have the moroso crank pulley removal tool or the snap on version of it. It'll make your life a hell of a lot easier. The tool will cost you about $30 - $50.
As for the guides:
http://www.c-speedracing.com/h...t.php
http://www.team-integra.net/se...=1044
I also recommend having the helms with you too.
mysuperslowej1
11
Oct 30, 2012 05:28 AM
[713]
Dec 2, 2009 07:51 PM
therivler1
Jan 11, 2008 08:07 PM
DJNauTicz
Mar 26, 2007 10:04 AM
mr98accord
May 28, 2003 10:00 AM
