DA/LS stuff for sale
For sale from an aborted honda challenge H4 build:
Items that are NIB:
Koni 3011's custom valved by the boys at koni for 750/950 rates, w/ koni's ht. adj. sleeve system and 750/950 hypercos - 1850.
Samco radiator hoses for b18a1 - $85
Topline 20 over oem replacement pistons (81.5mm) w/ rings - $110
Cometic 3-layer MLS 20 over gasket for LS block - $80
ARP rod bolts (8mm, iirc, whatever fits b18a/b) - $35
Sparco Circuit, in red. never used, but got some stains on it from moving it around the garage with dirty hands. FIA date escapes me, i'll go check it and edit. - sold!
Poly bushing set: rear LCA, front LCA, compensator, AND honda hard rubber TA bushings - $150
Might be more depending on what the person that buys the shell wants, or doesn't want w/ the car.
thanks!!!
Modified by bad-monkey at 6:25 PM 8/3/2006
Items that are NIB:
thanks!!!
bad-monkey
Oct 16, 2006 08:48 PM
bad-monkey
16
Sep 5, 2006 11:40 AM
