Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Problem with rear seatbelt.
Old Aug 2, 2006 | 09:29 PM
eL's Avatar
eL
Default Problem with rear seatbelt.
Ok here goes,
I was dynamat'ing my rear speaker deck so I took out the rear seatbelt. When I went to put it back, it was locked. I tried to feed the belt in order to get it loose again and now its all fed in and it wont give at all.
Any idea how to get this thing going again? Its sitting on the rear seat instead of being installed on the rear deck
Old Aug 2, 2006 | 10:35 PM
jonness's Avatar
Default Re: Problem with rear seatbelt. (eL)
Well, I've experienced this.
What I do is I pet the seatbelt.
I talk to it real quick saying to be nice to me please
Then I pull it softly as if it has feelings.
Old Aug 3, 2006 | 12:52 PM
06CIVICCOUPE's Avatar
Default Re: Problem with rear seatbelt. (jonness)
lol yea just rub it the right way !!
Old Aug 3, 2006 | 01:53 PM
tooann's Avatar
Default Re: Problem with rear seatbelt. (06CIVICCOUPE)
if you rub it more than 3 times it means that you're playin with it
Old Aug 3, 2006 | 02:50 PM
eL's Avatar
eL
Wow, 3 n00bs in a row.
Anyone with an intelligent answer?
Old Aug 3, 2006 | 03:01 PM
KJMRide's Avatar
Default Re: (eL)
They are very sensitive. You need to tip it back and forth slowly while pulling on the belt. As soon as the lock drops out the seat belt will unspool. Be very gentle and hold it level an it will come out.
Old Aug 3, 2006 | 03:28 PM
eL's Avatar
eL
Thanks for a real answer, I hope I can get that thing fixed.
Old Aug 4, 2006 | 03:56 AM
Type X's Avatar
Default Re: (eL)
http://auto.howstuffworks.com/seatbelt4.htm
Old Aug 4, 2006 | 02:34 PM
eL's Avatar
eL
Default Re: (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">http://auto.howstuffworks.com/seatbelt4.htm</TD></TR></TABLE>
I hope you were just being a smartass because that didn't help... or maybe I missed something.
I tried everything from telling the seatbelt how pretty it looked "hey, you look nice today, did you lose weight?" to turning the whole "mechanism" around and pulling on it. Nothing works
Old Aug 4, 2006 | 02:41 PM
Type X's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">
I tried everything from telling the seatbelt how pretty it looked "hey, you look nice today, did you lose weight?" to turning the whole "mechanism" around and pulling on it. Nothing works </TD></TR></TABLE>
it explains what the inner workings look like
i take everything apart
Old Aug 4, 2006 | 02:43 PM
eL's Avatar
eL
The sides of the thing are pretty clear but all I can see are some plastic gears. Eh, maybe I'll be brave like you and open it up.
Old Aug 4, 2006 | 10:57 PM
Demonis's Avatar
Seatbelts, to my understanding, work off of a tilt mechanism that when brakes are applied, the tilt leans and locks the belt... So you have to hold it in that VERY SMALL window that it releases the lock from, to get the belt to come free.
Old Aug 5, 2006 | 11:58 AM
eL's Avatar
eL
The problem is the belt is rolled all the way in so I don't have much room to feed in the belt like you usually do to get it loose.
Old Aug 5, 2006 | 04:32 PM
Demonis's Avatar
Default Re: (eL)
ooo.. yeah thats a bummer... maybe take it to a dealer, they may know how to get them to unlock.
Old Aug 5, 2006 | 05:38 PM
Type X's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">The problem is the belt is rolled all the way in so I don't have much room to feed in the belt like you usually do to get it loose.</TD></TR></TABLE>
clip something to it and use the extension you made as a "longer belt"
than unravel it
and unclip whatever you did
VOILA ... SLACK!
Old Aug 5, 2006 | 05:47 PM
eL's Avatar
eL
I have no idea what you mean ^
dglarson
Honda CR-V & Element
Jun 24, 2019 04:52 AM
JjuuN R
Suspension & Brakes
Jun 7, 2007 01:55 PM
Mr_Shide
Audio / Security / Video
May 31, 2001 09:30 PM
