accord techs please
Old Apr 23, 2002 | 07:05 PM
1 2 NV's Avatar
Default accord techs please
alright, i know someones done this. car 91 accord, motor 94ex. alright, heres the deal. motor went in pretty easy. problem is, it wont start. when and IF it starts, it will fire great for like 2 seconds then just run really rough. every sensor is hooked up and as far as i can tell it should b runnin fine. any guesses or something i might need to rewire??? i used the 91 accord harness, runnin the 94 ECU, dist and added the VTEC, and VTEC solenoid wires. weve tried moving the distributor to see if it will fire that way and no luck.
Old Apr 23, 2002 | 07:07 PM
Gennady's Avatar
New User
Default Re: accord techs please (hondaatwsu)
I'm not sure what this means, but it sounds like your ignition wires might be in the wrong firing order.
Old Apr 23, 2002 | 07:10 PM
1 2 NV's Avatar
Default Re: accord techs please (Wont be beat)
we have the right firing order because we looked at another 94EX dist.
Old Apr 23, 2002 | 07:11 PM
CmptchAV6's Avatar
how about the spark plugs what condition are they in?
Old Apr 23, 2002 | 07:13 PM
Gennady's Avatar
New User
By running really rough, do you mean misfiring?
Old Apr 23, 2002 | 07:16 PM
1 2 NV's Avatar
plugs r black, smell like fuel. doesnt seem to b gettin alot of spark either. trust me on this one, i got shocked, didnt hurt very much, we will try plugs and new wires tomorrow.
running rough like low low RPMs WHEN its running. most of the time it wont run.
Old Apr 23, 2002 | 07:18 PM
CmptchAV6's Avatar
change the spark plugs and wires then give us an update.
Old Apr 23, 2002 | 09:05 PM
Brandon's Avatar
Life is Suffering
Sounds as if the engine is not able to be fueled properly. The injectors may be sticking open because they are running too high of a duty cycle. If you use a 94 VTEC fuel pump, which is higher pressure, it should give enough fuel without over-running the injectors.
Old Apr 23, 2002 | 11:46 PM
H23 Power's Avatar
Default Re: accord techs please (vtec2k2)
my fuel pump is working fine with a F23A1...so i dont think that is it
Old Apr 24, 2002 | 08:59 AM
GraphiteAccord's Avatar
Default Re: accord techs please (01GSR)
coil, cap, rotar, wires, plugs. Could all cause a mis fire
Old Apr 24, 2002 | 06:48 PM
1 2 NV's Avatar
well **** today we got it solved, or should i say I did. ****** god damn thing, first there was a spark plug wire crossed, but heres the kicker, the ****** thing was OUT OF GAS. it wasnt near as low as when it left my shop, but yesterday the god damn thing was just bone dry. i do however think the MAP sensor was gettin a wrong reading. well that just means my part was done correctly, hehe. i was paid to install a motor and i did. but if u guys have ever done that, ya kinda feel obligated to get it runnin right.
Old Apr 24, 2002 | 06:52 PM
Gennady's Avatar
New User
HA! I told you!!
I know the feeling. I've run out of gas 6 times now.
Old Apr 24, 2002 | 06:55 PM
1 2 NV's Avatar
hey, it wasnt my car, hehe. closest time i had was when the car was sputtering into the gas station from around 10 blocks away.
Old Apr 24, 2002 | 07:08 PM
Gennady's Avatar
New User
My favorite is when you parked facing down on a big hill, and you gotta put the car into neutral and let roll down so that biatch starts up so you can make it the gas station...Dave can vouch for that one.
Old Apr 24, 2002 | 08:40 PM
1 2 NV's Avatar
well i dont think it helped that the car was parked facing downhill either. not a steep decline but none the less, prolly didnt help out much.
highazamotha
Feb 17, 2015 12:53 AM
digital_cowboy
Jul 7, 2007 06:37 PM
jhstanleyiii
Dec 7, 2005 12:04 PM
BlackAcGSR
Sep 20, 2003 07:47 PM
