Guage Cluster/clock/turn signals not working at all, need some help please
Old Aug 2, 2006 | 12:45 PM
unknown0001's Avatar
Default Guage Cluster/clock/turn signals not working at all, need some help please
hey guys, today I was on my way to a few stores and as i was coming off the highway, i noticed my cluster/RPM/Fuel/Engine Temp are not working. The clock on my eg dash also isn't working.
Everything was fine in the morning but now I can't get it to work.
I checked all the fuse(s) under the dash and hood and there is nothing blown. I checked to make sure all are seated well and the cluster doesn't work.
Also my left and right turn signals don't work as well, i checked the fuses and all look fine also.
my high-beams work, and daytime/night time lights work also.
any ideas?
Old Aug 2, 2006 | 12:47 PM
THC07's Avatar
Default Re: Guage Cluster/clock/turn signals not working at all, need some help please (Mr.RHTuner)
relays maybe, it gotta be somthing with the fuse or fuse box or wires to it. gota be.
Old Aug 2, 2006 | 12:55 PM
Default Re: Guage Cluster/clock/turn signals not working at all, need some help please (THC1107)
also to note: interior lights work
-guage cluster was not recently removed so i doubt the connections would come loose
Old Aug 2, 2006 | 10:10 PM
I took a further look and the fuse that blew was a 'backup' fuse under the dash. got that replaced and it's all good now
Old Aug 2, 2006 | 10:45 PM
95caliEG's Avatar
Did you check to see if any of the ground wires your lose or frayed (coming from the Cluster or going towards the fuse boxes?
Old Aug 9, 2006 | 02:03 PM
Default Re: Guage Cluster/clock/turn signals not working at all, need some help please (95caliEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95caliEG &raquo;</TD></TR><TR><TD CLASS="quote">Did you check to see if any of the ground wires your lose or frayed (coming from the Cluster or going towards the fuse boxes?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">I took a further look and the fuse that blew was a 'backup' fuse under the dash. got that replaced and it's all good now </TD></TR></TABLE>
90CRXZCSI16
10
Feb 1, 2013 12:11 PM
akcapr
11
Feb 27, 2011 09:55 PM
honda_conversion
Jun 22, 2007 11:31 PM
riceboy
Mar 21, 2005 01:07 AM
SiR HatchAlot
Mar 28, 2004 09:31 AM
