Suspension & Brakes Theory, alignment, spring rates....
Suspension for 99 Integra GS
Old Aug 2, 2006 | 07:45 AM
doinsd619's Avatar
Default Suspension for 99 Integra GS
Hello fellas, I just purchased a 99 Integra GS 5 speed and I'm new to the Honda/Acura modification scene. I bought this car for commuting but I would like it to handle better. I only have $450 to spend on the setup. I would like the ride to be somewhat factory smooth. I've ridden in a Honda Accord with Tokico blues with neuspeed springs and it was smooth as factory yet handled very well on the turns. What setup would you guys recommend? Coilovers or shock/strut and springs combo? Which brand and model? TIA
Ricky
Old Aug 2, 2006 | 08:31 AM
mrdeadman's Avatar
They let me pick
Default Re: Suspension for 99 Integra GS (doinsd619)
im probably going to get flamed for this but: i would look into omnipowers and ksports. those are what i would buy if i were to buy coilovers. either that or the koni yellow/gc setup.
Old Aug 2, 2006 | 09:44 AM
toshiro's Avatar
I bent my Wookiee
Not sure how much omni/ksports are, but I know koni/gc is waaay more than $450.
Old Aug 2, 2006 | 10:36 AM
mrdeadman's Avatar
They let me pick
Default Re: Suspension for 99 Integra GS (mrdeadman)
you can get a set of omnis for 650 shipped.
Old Aug 2, 2006 | 02:00 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doinsd619 &raquo;</TD></TR><TR><TD CLASS="quote">Hello fellas, I just purchased a 99 Integra GS 5 speed and I'm new to the Honda/Acura modification scene. I bought this car for commuting but I would like it to handle better. I only have $450 to spend on the setup. I would like the ride to be somewhat factory smooth. I've ridden in a Honda Accord with Tokico blues with neuspeed springs and it was smooth as factory yet handled very well on the turns. What setup would you guys recommend? Coilovers or shock/strut and springs combo? Which brand and model? TIA
Ricky</TD></TR></TABLE>
With that price range, I'd leave the springs and shocks stock, and get a good rear swaybar. I love my Comptech, the tiebar / reinforcement gets rid of subframe tearout worries and adjustability of swaybar stiffness is never a bad thing. Stock suspension and swaybar on full stiff got rid of the majority of bodyroll around town for me. Gave much less understeer for autocross as well, and even a little bit of throttle lift oversteer on turn in. There are plenty of other good brands, just be sure to look into some form of subframe reinforcement if you go too big.
Alternatively, you should be able to get a stock type-r set of springs fairly cheap. Though, if you want the type-r shocks too you'll have to change out the rear LCAs to mount them, as the mounting method is different for the different LCAs. I believe the stock type-r springs are only stiffer in the rear, but with a progressive rate to help keep ride quality, and a slight lowering all the way around.
Last option, a set of KYB AGX or Tokiko Illumina shocks and Eibach sportline or pro-kit springs. Should provide a nice lowering and relatively smooth ride quality.
Old Aug 2, 2006 | 04:18 PM
mrdeadman's Avatar
They let me pick
Default Re: Suspension for 99 Integra GS (TunerN00b)
ITR rear sway bar and the beaks kit=150 bones and some work. Used ITR coilovers is a good idea... or you could save your money.
I have the ITR rear sway bar and I love it. Worth every penny.
migz-da-reaper
Feb 6, 2010 04:39 PM
SupRlude01
Mar 21, 2007 05:57 AM
99SilverBullet.b45!
Nov 24, 2006 12:54 PM
LOwrestling2001
May 25, 2002 12:54 PM
