thottle bodies
Old Aug 2, 2006 | 06:42 AM
GoonieAsian's Avatar
Default thottle bodies
Quick question everyone, what is the difference from a D16Y5 thottle body and a D16Y8 throttle body? And are there other d series throttle bodies out there for a D16Y5, because i need one.
Old Aug 2, 2006 | 04:49 PM
slowcivic2k's Avatar
Default Re: thottle bodies (GoonieAsian)
Virtually all D,B,F,H throttle bodies are interchangeable, only minor differences would the the idle air bleed, in which case, stick with D and B series throttle bodies, the Y8 I beleive is 57mm, and the B16a throttle body is 60mm both will bolt up to that manifold.
The Y5 throttle body is small, and I believe has emissions inlets if I recall correctly, all I can definitly recall is that the intake system is clogged with emissions crap that you dont need, see if you can find a y8 manifold, or even a D16z6 manifold.
EJtypeR
Jun 17, 2015 08:01 PM
97njsilverhatch
Dec 4, 2010 11:59 AM
EGhatch33
May 9, 2006 09:48 AM
KURUPTinc
Jul 29, 2005 03:12 PM
DsMWookie
Sep 23, 2003 05:40 PM
