pm5 vs pm6
Old Aug 2, 2006 | 05:01 AM
civic minime's Avatar
Default pm5 vs pm6
going from pm5 to pm6 but not sure if auto and std work the same
Old Aug 2, 2006 | 07:09 AM
Loserkidwac's Avatar
Default Re: pm5 vs pm6 (civicdx(dpfi))
ECUs are different but i think the only problem with using the auto in a 5 speed car is you will get a CEL...which in most places won't allow you to pass state inspection...you shouldn't have a hard time finding a 5 speed pm6 and also if you ever plan to get it chipped for a possible turbo set-up or anything 90-91 pm6 are easier and most people won't chip the 88-89's but it is possible just tricky
Old Aug 2, 2006 | 07:43 AM
24TEN's Avatar
PHANTOM MENACE
If you haven't done the DPFI to MPFI conversion, I wouldn't work anyway because the PM5 is set to run two fuel injectors (primary and auxilary/secondary) and the PM6 is designed to run a dedicated fuel injector for each cylinder.
Old Aug 2, 2006 | 07:50 AM
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">If you haven't done the DPFI to MPFI conversion, I wouldn't work anyway because the PM5 is set to run two fuel injectors (primary and auxilary/secondary) and the PM6 is designed to run a dedicated fuel injector for each cylinder.</TD></TR></TABLE>
Word i just assumed hat was known...but you never know
Old Aug 2, 2006 | 09:19 AM
Voodooboy520's Avatar
Yeah, PM5's are pretty much useless unless you want to run DPFI.
blinger
Apr 3, 2007 01:21 PM
BLacK FirE
Jul 8, 2006 08:04 AM
pi282
Jan 13, 2006 09:29 AM
.Noah Fecks
Sep 3, 2005 08:16 AM
BME1986
Jul 13, 2004 06:05 PM
