Help!! GSR Motor, Low Idle
Old Aug 2, 2006 | 12:46 AM
munkeeboi's Avatar
Default Help!! GSR Motor, Low Idle
Need help tuning built GSR motor. It has JG manifold, fuel rail, fuel regulator, Skunk 2 cams, springs, retainers, Skunk 2 Pro Series Cam Shaft w/cam gears,stock computer.
Motor idles at 1000 RPM and it'll drop down or die out. Will idle at 1000 RPM for about 5 to 10 seconds and either die or go back up to 1000 RPM.
Anyone know what I need to do to fix this. What should the fuel pressure be at?
Thanks for any help I can get.
Old Aug 2, 2006 | 01:21 AM
dmacaalay's Avatar
Default Re: Help!! GSR Motor, Low Idle (munkeeboi)
it has skunk2 cams and skunk 2 pro series camshafts?? wow.. how many cams does yer gsr have?? jk!! nah.. are they stage 2's or 3's or 1's?? stock bottom end?? and what size injectors are you using?? i would definitely get some engine management because you changed quite a bit there..
TomIntegraGSR
May 29, 2007 03:55 PM
MatHadder
35
Mar 15, 2007 07:01 PM
escourt23
Dec 15, 2005 06:59 PM
B00ST2nR
Aug 14, 2002 06:31 PM
