Turbo GSR build...waddya think about this
Old Aug 1, 2006 | 11:39 PM
bjfisher's Avatar
Default Turbo GSR build...waddya think about this
im doing a mild turbo build on my 163k mile b18c1, shooting for 400whp with my gt35r. im building the block only, with JE 9:1 pistons, Eagle H Beam Rods and ARP rod bolts and head studs.
my main concern is the sleeves, and i do not want to put out the money to have my block Benson sleeved like i would in a perfect world. ive heard negative things about block guards, and i also know that another option is block posting. what do you guys suggest i do. of course, i want it to be reliable, as this is a daily driven car.
also, what head gasket should i use, and what kinda bearings ACL or OEM hondas?
Old Aug 2, 2006 | 05:47 AM
TheShodan's Avatar
Moderator
Default Re: Turbo GSR build...waddya think about this (bjfisher)
Wait for the money and sleeve. Since its daily driven, as you say..
Old Aug 2, 2006 | 06:52 AM
VisualAutoMotoring's Avatar
400whp is on the threshold but many many people have done it before. Just make sure you check the block out and make sure everything is a-ok. But again many people have done that or more on stock sleeves.
A stock gasket is the way to go although we have had good success with Cometic gaskets also.
Most people would go with OEM bearings but we use ACL Standards in most of our builds and they do just fine. ACL Standards are oversized so most machine shops can machine it to the exact specs.
Old Aug 2, 2006 | 07:07 AM
95BlkGSR's Avatar
im in the same boat ...
Cp pistons, Manley Rods ACL bearings
its my Daily Driver and im worried about sleeves
will check back on opinions also
bump
Old Aug 2, 2006 | 07:23 AM
Lonnieboosted's Avatar
Sleeve it unless you want to end up like my old block. this wasn't a DD and it had DFI management on there with Race gas.
Old Aug 2, 2006 | 07:47 AM
bjfisher's Avatar
^^ did you have a good tune? how much power were you putting out?
Old Aug 2, 2006 | 08:03 AM
Default Re: (bjfisher)
The tune was fine, this was in 2000, really dont know how much power, but I used to give single turbo Supras the break
Old Aug 2, 2006 | 10:13 AM
quicksilver1689's Avatar
i ♥ snails
let that be an example the stock sleeves can only take soo much pressure and stress until they distort or crack.
Old Aug 2, 2006 | 10:37 AM
teamsoy1320's Avatar
not to thread jack but why is every one scared of stock sleeves
Old Aug 2, 2006 | 10:52 AM
Default Re: (teamsoy1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamsoy1320 &raquo;</TD></TR><TR><TD CLASS="quote">not to thread jack but why is every one scared of stock sleeves</TD></TR></TABLE>
Look above
Old Aug 2, 2006 | 10:58 AM
BoostedEG6's Avatar
Default Re: (Lonnieboosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnieboosted &raquo;</TD></TR><TR><TD CLASS="quote">Look above</TD></TR></TABLE>
well you also have think that tunning and the tunning softwear has come a long way since 2000. I have seen alot of 500+whp cars on stock sleeves and they have lasted for a long time.
But it comes down to your tune and your build. If its built good and tunned good then you wont have a problem.
Old Aug 2, 2006 | 01:13 PM
bjfisher's Avatar
yeah, tunning has so much to do with it. i live in ohio and im considering driving to PA to have jeff evans tune it, im not sure yet though
Old Aug 2, 2006 | 01:58 PM
turbotime's Avatar
there are people making 600whp on stock sleeves, its all in the tune... 400whp on stock sleeves will be fine as long as the tune is spot on, and you dont overboost/mishshift you have nothing to worry about
Old Aug 2, 2006 | 03:02 PM
bjfisher's Avatar
^^ cool, thanks for the reassurance
Old Aug 2, 2006 | 03:30 PM
Snafubmx234's Avatar
It comes down to your piston-to-wall clearance and tune.
If you run what the piston manufacturer says, then you'll be fine (with a good tune).
Old Aug 2, 2006 | 03:35 PM
KeyserSoze's Avatar
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">there are people making 600whp on stock sleeves, its all in the tune... 400whp on stock sleeves will be fine as long as the tune is spot on, and you dont overboost/mishshift you have nothing to worry about</TD></TR></TABLE>
Dont forget to mention that this is 600whp on RACE gas! Pump gas is a totally different story......
OP: Are you going to run race gas or just pump gas? Unfortunately I live in cali and all we have @ the pump is shitty 91. I will be using a mix of 91 and 100 LL avgas.
Old Aug 2, 2006 | 03:52 PM
bjfisher's Avatar
Default Re: (Snafubmx234)
what do you mean? im running stock size 81mm pistons
Old Aug 2, 2006 | 03:53 PM
bjfisher's Avatar
Default Re: (KeyserSoze)
ill be running premium daily, here in ohio i can get 92+93
Old Aug 2, 2006 | 06:49 PM
cuin9sec
Guest
Posts: n/a
i hit 395whp on stock gsr...dont see why 400 wouldnt be a prblem as long as its tuned properly.
Old Aug 2, 2006 | 07:42 PM
bjfisher's Avatar
how long have you been drivin it?
Old Aug 2, 2006 | 07:50 PM
SovXietday's Avatar
Drive around on a low boost setting as a DD and get a good tune.
Old Aug 2, 2006 | 08:37 PM
ringgold's Avatar
Default Re: (SovXietday)
Im a believer in stock sleeves. Others are right, if the tune is good and done by a trustworthy tuner they will hold some power. Mine have been holding 300whp+ for a little while now, and Im not sure what my piston/wall clearance is, but I beat on my engine when I drive it and it holds just fine on 93 octane. Its not a daily car but could be.
My motor has about 5k on it now with a mild build like you are wanting to do. If it last till 10k or so Im going to rebuild it again and more than likely go up to a 81.5mm bore on the same stock sleeves. Maybe shoot for 400whp+ on that setup when the time comes.
Old Aug 2, 2006 | 10:10 PM
bjfisher's Avatar
good to hear. and yeah my low boost/dd will be set around 200whp
Old Aug 2, 2006 | 10:12 PM
Soccerking3000's Avatar
Default Re: (ringgold)
where in ohio are you from? if you dont mind me asking, as for keeping stock sleeves, you'll be fine its no problem
Old Aug 2, 2006 | 10:13 PM
bjfisher's Avatar
just east of columbus
