Shifting problem
Old Aug 1, 2006 | 10:31 PM
mrnewguy's Avatar
* B A N N E D *
Default Shifting problem
Im having a problem with my shifting, like when im in first gear into second gear, it feels like something is sticking like in the way or something like kinda have to use force any idea?
Old Aug 1, 2006 | 11:05 PM
RSXflip's Avatar
Default Re: Shifting problem (mrnewguy)
acura made the rsx trannies suck. theyre having a problem with their synchros meshing properly when shifting. it happens to everyone with a rsx. switch out the fluid with royal purple like me. got rid of about 99.9% of the grinding
Old Aug 2, 2006 | 11:16 AM
ScuDC5's Avatar
its a timing issue with 5th and 6th gear. Take it to Acura and recreate the problem for a tech (which I've yet to be able to do, stupid car...) and they will replace the synchros. There is a service bulletin out for this. 2nd and 3rd gear grind, been there since 2003.
Changing the tranny fluid helps hide it for a bit though.
Old Aug 2, 2006 | 07:27 PM
n7plus1's Avatar
Default Re: (ScuDC5)
there was a TSB released BUT it technically only applied to the '02-'04 model within a certain VIN pool. I have the same issue, when the tranny's cold. Im switching out soon to the amsoil fluid i have sitting in the garage
Old Aug 5, 2006 | 10:54 PM
Devilboiz's Avatar
just take it to the dealer and tell them to fix it. that is the best thing to do. don't ever go to ur local shop and waste ur time and money there cause they only fix older cars
Old Aug 6, 2006 | 11:17 AM
02ep3's Avatar
Default Re: Shifting problem (Devilboiz)
im havin the same issue 2nd to 3rd in my ep...gets a shitty grind when shifting at a high rpm...
Old Aug 6, 2006 | 12:28 PM
Blue03RSX's Avatar
Default Re: Shifting problem (RSXflip)
the usdm trannies suck. they had recalls on the synchros and i recently tore the spider gears apart. I bought a type r trans and its geared perfect for me. there is no loss of power when changing into another gear
Old Aug 6, 2006 | 01:08 PM
mraza's Avatar
so just to make it clear there is a recall on the transmission???? and how would I find out about it.. does anyone have a link??? Im grinding shifting from 1st to 2nd aswell :-/
Old Aug 6, 2006 | 09:29 PM
MyK20Rips!'s Avatar
Default Re: Shifting problem (Blue03RSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue03RSX &raquo;</TD></TR><TR><TD CLASS="quote">the usdm trannies suck. they had recalls on the synchros and i recently tore the spider gears apart. I bought a type r trans and its geared perfect for me. there is no loss of power when changing into another gear</TD></TR></TABLE>
wait if you bought the type-r tranny wouldnt that be for the right hand drive setup?
or did you swap synchros out of the type-r tranny?
Old Aug 7, 2006 | 01:17 PM
Blue03RSX's Avatar
Default Re: Shifting problem (MyK20Rips!)
if its still under warranty take it to your local acura dealer if not its gonna be pretty expensive and no the type r trans is not only for right hand drive
Old Aug 11, 2006 | 12:32 AM
Prieto_69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue03RSX &raquo;</TD></TR><TR><TD CLASS="quote">if its still under warranty take it to your local acura dealer if not its gonna be pretty expensive and no the type r trans is not only for right hand drive</TD></TR></TABLE>
I took mine to the dealer and they said i have to pay $85.00 just to get the car in and check. After that if the warranty don't cover whats wrong, I have to pay for it. Hey let me know if you guys have this problem at the dealer too.
Old Aug 11, 2006 | 09:22 PM
touge_dc5's Avatar
2nd to 3rd high rpm shifting it make a loud grinding noise
DJ4Jesus77
Honda Civic (2001 - 2005)
10
Oct 8, 2010 08:57 PM
sportinjected
Jul 9, 2008 08:21 PM
infamouskillas
May 17, 2008 09:56 PM
Type_Rb18c5r
Mar 12, 2008 03:43 PM
atmosphere
10
Sep 20, 2006 06:26 PM
