What oil are you turbo guys using?5,10,15w
Old Aug 1, 2006 | 09:37 PM
moesrex's Avatar
Default What oil are you turbo guys using?5,10,15w
Whats the best oil to use?mobil,castrol,royal purple?
Old Aug 1, 2006 | 10:05 PM
F20Cteg's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (moesrex)
5W-30 from the 99 cent store.
Old Aug 1, 2006 | 11:56 PM
importdude2000's Avatar
10-40 castrol gtx
Old Aug 2, 2006 | 12:45 AM
torqueless's Avatar
AMSOIL SYNTHETIC best oil out there scientificly proven. check out amsoil.com for comparison on all other top name synthetics.
use heavy oil for turbo such as 20-50. it lubes center cartridge better, to reduce heat and friction.
Old Aug 2, 2006 | 01:12 AM
fuccarlos's Avatar
ive used castrol sae 30hd for awhile now
Old Aug 2, 2006 | 03:45 AM
Finland's Avatar
I'm currently using castrol dino 5w30 while breaking in my motor, I'll be switching back to castrol synthetic in a few hundred more miles. I use a 5W oil because Hondas run relatively tight clearances, plus since your cams don't have bearings...it's best to have oil flow to the head as quickly as possible during a cold start.
Old Aug 2, 2006 | 07:22 AM
jcintegratyper's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (torqueless)
I don't know about using heavy 20w-50 oil because honda recoments 10w-30 for there engines, but for the turbo I don't know what oil is best(heavy or not heavy).
Any body????
Old Aug 2, 2006 | 07:28 AM
a1320addict's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (jcintegratyper)
I use what's on my oil cap, 5W-30 Castrol GTX.
Short intervals between oil changes though.
Old Aug 2, 2006 | 07:40 AM
DontBlink's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (a1320addict)
Bradpenn 10w30 racing oil(the old kendall formula)
http://www.bradpennracing.com/....html
Old Aug 2, 2006 | 07:43 AM
RyanEJ8's Avatar
I use Mobil1 10w-30.
Old Aug 2, 2006 | 08:00 AM
nonvtecD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">I use what's on my oil cap, 5W-30 Castrol GTX.
Did that Honda come boosted?
Old Aug 2, 2006 | 09:04 AM
j-spec_cc2's Avatar
iw as lokoing on the back of an issue of Import Tuner and i saw that gReddy has their own line of oil.
they say that one of their products (GR-2) is specifically designed for turbos. it's a 5w-40. anyone use this oil before?
Old Aug 2, 2006 | 10:12 AM
rudebwoy's Avatar
Mobil-1 10w30 for the winter ,and 10w40 summer. I switch to royal purple for 2 oil changes, but it does not clean the motor as well as mobil 1. and I tried that synchro max **** in my transmision and it destroyed my synchros the same day it was used. so I hate royal purple now. mobil 1 all the way
Old Aug 8, 2006 | 07:07 PM
80884's Avatar
Default Re: (rudebwoy)
http://www.lelube.com/
Some pretty good stuff, not many know about it tho. Better than Mobil 1?
http://www.lelube.com/Technical_ProductTesting.asp
Old Aug 8, 2006 | 07:19 PM
y7turbo's Avatar
Default Re: (80884)
mobil 1 10w30
Old Aug 8, 2006 | 07:57 PM
eg:R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">Mobil-1 10w30 for the winter ,and 10w40 summer. I switch to royal purple for 2 oil changes, but it does not clean the motor as well as mobil 1. and I tried that synchro max **** in my transmision and it destroyed my synchros the same day it was used. so I hate royal purple now. mobil 1 all the way</TD></TR></TABLE>
same thing happen to me also on the tranny, but i used gm synchromesh. only to my sohc trannys
Old Aug 8, 2006 | 08:01 PM
LudaChris's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (F20Cteg)
R u serious, you think that it worh it, as much money you put in your motor.
Old Aug 8, 2006 | 08:03 PM
LudaChris's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (LudaChris)
Best oil, flat out. http://www.lelube.com/
Old Aug 8, 2006 | 08:19 PM
MidShipCivic's Avatar
Shut up you dont know what oils best, I personally use redline racing oil 20wt .
Old Aug 8, 2006 | 09:50 PM
purpleh22's Avatar
Default Re: (MidShipCivic)
As said earlier, the only one that is test proven to be better (less scuffing under load/heat) is Amsoil synthetic. I use Series 2000 20w-50w racing oil. You can find cheaper oil, but not better.
Old Aug 8, 2006 | 10:09 PM
Let see this test and if I see nothing but fancy graphs with bar charts you know whats comming out of my mouth.
Old Aug 9, 2006 | 07:41 AM
delslo93's Avatar
I was using some cheap synthetic for my motor until it kept gunking up in the turbo. Now I switched to Mobil 1 10W-30...hey if its good enough for the $50,000+ corvette, cadillacs, and vipers its good enough for me
Old Aug 9, 2006 | 07:44 AM
80884's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaChris &raquo;</TD></TR><TR><TD CLASS="quote">Best oil, flat out. http://www.lelube.com/
Don't throw out what this guy is saying. I'm doing some research on this stuff right now and waiting for some tests to get back to me. Follow that link for the Leading Edge Oil, there are 6 videos in the product testing section, they have charts, also under dyno testing - numerous dyno charts for the people that like them and also under dyno testing a vid showing people dynoing and changing oil then making more power. Its not about power but more about protection but isn't having both the way to go?
RP took away trans grind for me in my civic hatch when I had it. I've been running the RP oil in my sti since 11,000 and it is fine. Once I get this test back I will post it up.
How do you know the engine isn't cleaned as well? What do you mean by this and what test did you do to prove this?
Old Aug 9, 2006 | 08:01 AM
BoostedEG6's Avatar
Default Re: What oil are you turbo guys using?5,10,15w (80884)
I use Torco 10w30 synthetic blend.
Old Aug 9, 2006 | 12:06 PM
yee SERIOUS's Avatar
i use castrol synthetic blend. 20-50 year round. stock motor
