CUTTING SRS WIRE ON CLUSTER? GOOD OR BAD?
HELLO PEOPLE. I COULDNT RESET THE SRS AND THE ABS LIGHT SO I JUS CUT THE YELLOW WIRE AND THE LIGHTS DID GO OFF AND I WAS JUS WONDERING IF THE YELLOW WIRE IS ANYTHIN ELSE BESIDE THE ABS AND THE SRS LIGHTS? AND IF ITS A GOOD OR BAD THING? PLEASE AND THANK YOU.
yea but when i cut the yellow wire the abs light also went out.. ? iono i couldnt reset it and i did what all the site said and it still didnt wrk and **** so i jus cut the wire. anythin bad bout it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 »</TD></TR><TR><TD CLASS="quote">yellow wire is SRS only, no ABS on it.
You could of simply unpuged it from the back of the gauge cluster to get rid of the light, but there is a sequence with a jumper that you do to reset it.</TD></TR></TABLE>
On 98-01 clusters, the ABS was also on the SRS plug. The yellow wire supplies power to the light.
matt87
Nov 22, 2005 03:00 PM
CXHatchback
May 8, 2003 07:36 AM
