New BB6 Owner, got a couple quick questions
Old Aug 1, 2006 | 06:56 PM
CRX A4's Avatar
Default New BB6 Owner, got a couple quick questions
Hey fellas,
Just picked up a 1997 BB6 prelude, Eucalyptus green, 5 speed, Just had some quick questions as this is my first prelude
Aside from the basic maintenence, is there anything specific i should do/check for on the car? I checked the rear wheel bearings, they seemed fine, i noticed the suspension creaks in the rear, so i'm assuming i have to get the updated perches
The car has a decent amount of miles on it so i was hoping to get some tips on preventative maintence
Any help would be great
Thanks
Old Aug 1, 2006 | 08:33 PM
asdfsad's Avatar
Default Re: New BB6 Owner, got a couple quick questions (CRX A4)
The auto tensioner tends to fail on many of the 5th gens. you should look into getting that fixed/replaced when/if it is going out.
Old Aug 1, 2006 | 08:55 PM
prelude1897's Avatar
Default Re: New BB6 Owner, got a couple quick questions (asdfsad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asdfsad &raquo;</TD></TR><TR><TD CLASS="quote">The auto tensioner tends to fail on many of the 5th gens. you should look into getting that fixed/replaced when/if it is going out.</TD></TR></TABLE>
+1
Old Aug 1, 2006 | 09:03 PM
asdfsad's Avatar
oh yea i forgot to add; I would have edited my OP, but 1897 already quoted me
when it rains, your trunk will flood up with water. No joke. Its not like it floods all the way up, but there will be a significant amount of water under your spare. It is caused by a few things. a bad tail light gasket, and/or clogged sunroof drains. I will try to post up more as i can think of them.
Old Aug 1, 2006 | 09:49 PM
liukangus's Avatar
when it rains, your trunk will flood up with water. No joke. Its not like it floods all the way up, but there will be a significant amount of water under your spare. It is caused by a few things. a bad tail light gasket, and/or clogged sunroof drains. I will try to post up more as i can think of them. </TD></TR></TABLE>
Never had that problem before, but I guess it will happen if any of those things listed goes bad. My lude was perfect minus the auto tensioner being on its way out. Glad to see another Eucy Green lude owner in the forums.
Old Aug 2, 2006 | 08:48 AM
1epmugenlude's Avatar
Ive never had any leakage problems with my 5th gen. I would do the manual tensioner swap as well, change t-belt / water pump while you are at it, depending on how many miles it has change the transmission fluid to.
Old Aug 2, 2006 | 10:54 AM
asdfsad's Avatar
Default Re: (1epmugenlude)
shoot really? none of you guys get water in the trunk? damn ive seen a few topics on here asking on how to fix the problem, but i guess it doesnt affect as many people as i thought. meh. maybe it CAN happen to you
Old Aug 2, 2006 | 11:43 AM
integra15's Avatar
Default Re: (asdfsad)
Yes it is common for water in the trunk, not just preludes either.
Old Aug 2, 2006 | 11:56 AM
Nick99's Avatar
I thought it was 97-98 mostly. I believe 1999 had the newer part.
Old Aug 2, 2006 | 07:58 PM
CRX A4's Avatar
Thanks for all the replies, they are greatly appreciated
I will definitly check on the tensioner, the timing belt, water pump and all were just replaced recently, where can I get a manual tensioner from?
I dont think i have the trunk water problem, it has been raining these last couple days and the trunk stays dry, so i guess i'm lucky
Thanks again, feelin the love from the prelude owners
Old Aug 3, 2006 | 12:51 AM
You can get most of the parts from a dealership, or even here on the site. Here is a useful link for the conversion as well. Good luck and enjoy the Prelude.
https://honda-tech.com/zerothread?id=549516
Old Oct 16, 2011 | 04:04 PM
thelonerangers's Avatar
If somone can get me more info on the water in the trunk problem. Was cleaning out my car and noticed a very small amount of water in the trunk. Where do I check the sunroof? And I have noticed one of the tail lights with a little moisture in it but I think its opposite side. Any help would be fantastic. Thank you in advance.
Old Oct 17, 2011 | 07:55 AM
titotapatio's Avatar
I just removed the plugs in the bottom of mine and never had the problem again
Old Oct 18, 2011 | 01:37 PM
There aren't any downsides to removing those plugs? No moisture build up in the summer or anything like that? Wanna check all angles before I just do it.
noire
May 15, 2005 09:02 AM
nikon70
Jan 6, 2005 08:12 AM
DiamondDave
Aug 20, 2003 02:38 PM
Auraraptor
Aug 24, 2002 05:00 PM
