4 Quarts Of Oil?
Old Apr 23, 2002 | 03:56 PM
Fooman's Avatar
Default 4 Quarts Of Oil?
i lost my manual. is it four quarts of oil for LS? i can't remember. please answer soon, i'm changing right now. thanks.
Old Apr 23, 2002 | 03:57 PM
KraZyCHOWMEIN's Avatar
Default Re: 4 Quarts Of Oil? (Fooman)
i usually throw in about 4.5 in my geezer
Old Apr 23, 2002 | 03:59 PM
IN VTEC's Avatar
maybe a little more than 4...use the dipstick.
Old Apr 23, 2002 | 04:00 PM
GSRaCeRbOI's Avatar
i dont have an LS.. but i usually put in like 4.25... put in 4 and then use your dipstick to see if you need to add more... and add it gradually until your at the full line...
Old Apr 23, 2002 | 04:29 PM
neo1z's Avatar
Default Re: 4 Quarts Of Oil? (GSRaCeRbOI)
ive always put 4.5 in the gsr ---
Old Apr 23, 2002 | 05:57 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 4 Quarts Of Oil? (neo1z)
Weird, I always put in 4 even after letting it drain for about 15 minutes (the oil is hot, too), and that always brings it right up to the full mark on the dipstick.
Old Apr 23, 2002 | 08:24 PM
ndustryalGSR's Avatar
Default Re: 4 Quarts Of Oil? (PatrickGSR94)
Should you all really be working on your own cars if you don't know how much oil to put in? J/K
Helms says(*in my best "Survey Says" voice*):
4.0 quarts for B18B oil change with filter
4.2 quarts for B18C oil change with filter
Old Apr 23, 2002 | 08:53 PM
RC211V's Avatar
Default Re: 4 Quarts Of Oil? (ndustryalGSR)
LS 4
GSr 5
Old Apr 23, 2002 | 10:35 PM
Hapa DC5's Avatar
Default Re: 4 Quarts Of Oil? (JDMintegGSR)
5 in a gsr???? errrnt don't think so brother. 4.5 in a gsr at most.
Old Apr 23, 2002 | 10:48 PM
GZR4DR's Avatar
Default Re: 4 Quarts Of Oil? (NemesisGSR)
I would recommend going with what the helms manual says. Read what that other guy posted.
Old Apr 24, 2002 | 04:47 AM
Regular Series's Avatar
What year? My 98 takes four quarts exactly...the GS-R and Type R take more, so they don't apply to us non-VTECers.
Old Apr 24, 2002 | 05:06 AM
Community Builder
Then how come 4 quarts puts me exactly at the full mark in my GS-R, even days after changing the oil it's still exactly on the full mark (w/ filter change).
Old Apr 24, 2002 | 08:21 AM
Rtzx9r's Avatar
GDD 1%
Because .1inches on the dipstick makes a large difference on how much to put in. If there is ANY change in 1 dipstick to another then you will see a difference.
Old Apr 24, 2002 | 09:37 AM
sant0ki's Avatar
Default Re: 4 Quarts Of Oil? (Rtzx9r)
gsr is 4.2
Old Apr 24, 2002 | 10:18 AM
Fooser's Avatar
Default Re: 4 Quarts Of Oil? (sant0ki)
GSR is around 4.25 quarts.
If you dont remove the oil filter you might not have to fill as much.
Old Apr 24, 2002 | 10:21 AM
Trigun's Avatar
Default Re: 4 Quarts Of Oil? (Fooser)
i put 4.5 in my last oil change ... helms says 4.25 but a little over should be ok.
Old Apr 24, 2002 | 10:30 AM
mickey513's Avatar
Default Re: 4 Quarts Of Oil? (Trigun)
I put 4.5 on my 94gsr. I know I'll be burning it up sooner or later.
Old Dec 2, 2007 | 08:35 PM
egjdmcivichatch's Avatar
Default Re: 4 Quarts Of Oil? (IN VTEC)
sorry to bring back this old thread, but i have a jdm b18b in a 95cx, did my first oil change motor only has 43,000 on it and i added 4 quarts of oil which put me over the top dot. ive been driving her kinda hard to burn some oil to get it just right. i was wondering if im ok as far as rings, seals,compression test, etc.... i read people need to check those things but they added 6-7 qrts, or was way over the line.
car drives fine no noises, anything, just was a tad bit sluggish when i first drove her but the second time everything felt normal.
thanks appreciate the input.
Old Dec 2, 2007 | 08:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: 4 Quarts Of Oil? (egjdmcivichatch)
As long as the overfill is minimal, you will be fine. In the future though:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">...use the dipstick</TD></TR></TABLE>
Old Dec 2, 2007 | 08:53 PM
Default Re: 4 Quarts Of Oil? (Padawan)
k kool i was usin the dipstick, put 3 qrts, was barely half then poured the 4th qrt thinkin it was going to be right to the line but ended up goin over.
just glad to know everything is straight
thanks
just checked it its right at the top hole.
Old Dec 2, 2007 | 09:08 PM
IN VTEC's Avatar
You have to check the oil level on level ground and after you've run the engine until the oil pressure light goes out after just doing an oil change.
The oil filter and oil passages will take about .5 quart. To compensate for this, I add oil up to 1/2 an inch over the top dot before starting the car to save myself a little time. I can usually get it on the first try.
EJ8 GSR-T
Jan 6, 2007 09:18 AM
TTE TEG
Oct 21, 2005 05:54 AM
JamaicanDM
Jan 13, 2005 05:33 PM
iNtoXicaTedSPOON
Oct 4, 2004 07:41 PM
jaredfmn
Jun 19, 2002 08:45 PM
