crx with b16-check engine
Old Aug 1, 2006 | 03:27 PM
tnereffidxmitch's Avatar
Default crx with b16-check engine-help!
i have an 89 crx si with a JDM b16a sir-2. i am runnign a PR3 ecu with the OBD0-OBD1 conversion/jumper harness. my check engine light is on but the car runs fine. the idle is sometimes wavoring up and down a few hundrew rpms....expecially when its cold.
my friend and i assumed possibly the idle air temp sensor....any suggestions?
also which pins need to be pulled to get the dash to flash so i can get the code? and how do u do it?
ive never messed with an ecu's pins before so i dont want to mess up.
p.s.-this ecu is running a custom program which was created on the dyno. if that matters any.
Modified by tnereffidxmitch at 8:10 PM 8/1/2006
RockosCRX
Nov 25, 2011 02:58 PM
wesleywhite989
Jul 23, 2008 05:22 PM
88crx1589
Jul 29, 2006 03:17 PM
90jdmcrxdude
14
Jan 30, 2006 10:55 PM
