F22B parts?
Old Aug 1, 2006 | 02:05 PM
slamdlude's Avatar
Default F22B parts?
I bought a 93 prelude with an F22B motor swap already done and now my waterpump has gone bad, I am having trouble finding a new pump does anyone know where i can find a pump for this emgine?
Old Aug 1, 2006 | 02:18 PM
InvaderTrax's Avatar
Pretty sure an H23 water pump should fit
Old Aug 1, 2006 | 02:25 PM
slamdlude's Avatar
Default Re: (InvaderTrax)
v-tech pump has the wrong hole pattern.
Old Aug 1, 2006 | 03:03 PM
Default Re: (slamdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdlude &raquo;</TD></TR><TR><TD CLASS="quote">v-tech pump has the wrong hole pattern.</TD></TR></TABLE>
The problem is that the F22B head doesn't have a space for the antenna
Old Aug 1, 2006 | 03:04 PM
shutta's Avatar
that's why he suggested h23 non vtec model. I have one from my odl h23 if you are interested
Old Aug 1, 2006 | 03:14 PM
tacticalcustoms's Avatar
Default Re: (shutta)
LOL... no the h23a pump won't work.. too big. I did the swap in my old lude. and the water pump you have to get is for the f22a1 sohc.. and then use a h23a timing belt.. the front main and rear seals are the same as the f22a1 and same with oil pan seal. use the h23a valve cover gasket and gromits.
Old Aug 1, 2006 | 03:19 PM
slamdlude's Avatar
Default Re: (tacticalcustoms)
yeah the sohc pump bolts right up but the timing belt won't go on with that pump. is the H23 belt longer? I will almosttry anything at this point but dont want F-up my motor by doing something crazy that doesn't work. Also what tensioner do i need to use? the H23?
Old Aug 1, 2006 | 03:54 PM
I'm wondering. Has anyone ever just gone to the dealer and asked??
Old Aug 1, 2006 | 04:04 PM
slamdlude's Avatar
my dealer is absolutely no help. they can't do anything without a VIN.
Old Aug 1, 2006 | 04:31 PM
yes. the h23a is 1 tooth longer or so. my friends dad is a great mechanic at the honda dealership... he was the one that did my motor.. I did lots of research to put the f22b into my lude. from finding all the gaskets and what not and what motor to get them from... the h23a belt is a bit longer.
Old Aug 1, 2006 | 06:27 PM
twistedbydezign's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering. Has anyone ever just gone to the dealer and asked??</TD></TR></TABLE>
are you kidding?!?!?! the chick who answers the phone at the dealership asking how to direct your call is more help than the parts people, especially if you are going to ask about a jdm motor....
slamdlude
Feb 14, 2011 10:50 PM
prelittlelude
Jan 14, 2004 09:56 PM
fastlude69
May 13, 2003 11:29 PM
