no fuel, guages lights or signals
Old Aug 1, 2006 | 09:06 AM
DAcraze's Avatar
Default no fuel, guages lights or signals
bike wont start, i took the fuel line off and the fuel pump still shoots fuel up when the key is turned on. but my bike wont start it just keeps cranking. i had it runnin via funnel connected to fuel line and the guages, signals, lights,and flashers wouldnt work. i got 2 used relays to replace the other ones and its doin the same thing.
Old Aug 1, 2006 | 09:11 AM
MSchu's Avatar
My Name is Nobody
Default Re: no fuel, guages lights or signals (DAcraze)
did we check for spark?...
Old Aug 1, 2006 | 09:14 AM
DAcraze's Avatar
Default Re: no fuel, guages lights or signals (MSchu)
yes its getting spark, its definately fuel related cause when i disconnect the fuel line and put a lil fuel in the line myself, itll run for a few minutes and then cut off
Old Aug 1, 2006 | 09:19 AM
ceas's Avatar
It might help if you were to actually give information on the bike in question.
Old Aug 1, 2006 | 09:21 AM
DAcraze's Avatar
Default Re: no fuel, guages lights or signals (ceas)
92 yamaha fzr 600
Old Aug 1, 2006 | 09:34 AM
MSchu's Avatar
My Name is Nobody
so this is a carb bike... dp youl feel it is fuel starvation or flooded? overwhelming smell of fuel? perhaps it is getting to much fuel and flooding out? what color are the plugs? need a bit more info. could be something as simple as a plugged line between the pump and the carbs... also fuel filter could be all junked up and not allow fuel delivery. does that bike have a petcock? are you sure of proper position of the petcock? try in "on" and "Reserve"
Old Aug 1, 2006 | 10:10 AM
DAcraze's Avatar
yes the bike does have a petcock, i tried it in "on" and "reserve" same thing, i take it the fuel pump squirts just a lil gas durin start up and when the bike starts the fuel pump takes over from there? and it probably delivers the fuel in pulses. im thinkin a clogged line now
Old Aug 1, 2006 | 10:20 AM
MSchu's Avatar
My Name is Nobody
carbs on bikes usually work via gravity feed and then negative pressure... if you have a torn diaphragm flow will not be consistent. checking plug lines and/or filter are fairly easy to do... if you have never changed out a filter just do it, it is cheap insurance. also if your mechanically inclined you can have plugged orifices in the carb units themselves... pilot circuits and main/secondary jets etc. if your floats are bad, they wont keep the proper amount of fuel in the bowls, leading to fuel starvation. Check air fuel/ adjustment screw, there is a mass screw for "across all four" carbs and there are individual screws for sync'ing...
Old Aug 1, 2006 | 10:44 AM
DAcraze's Avatar
well the carbs were just cleaned by a local motorcycle shop. he told me i needed a new relay asssembly. i heard it run before i picked it up. got the used relay last night and i hear the "click" for the fuel pump when i turn the key to the ON positition but all it does is crank, but would u know if that relay controls the lights and guages also?
Old Aug 1, 2006 | 10:56 AM
MSchu's Avatar
My Name is Nobody
I would imagine it is seperate, a fuel relay and a lite/ignition relay. But I can not confirm that, I dont own one of these bikes.
Old Aug 1, 2006 | 03:23 PM
DAcraze's Avatar
checked filter and its good. the "on" and "reserve" switch is good. pulled the tank out and now im thinking its the fuel pump
Christopherian1982
Dec 31, 2008 08:17 AM
Rah Rah
Honda Motorcycles
May 17, 2006 04:22 AM
slowassR
Honda Motorcycles
Nov 20, 2003 06:43 PM
DubyaAye
Honda Motorcycles
Apr 30, 2002 11:14 PM
