What all would i need to install the stereo into the cup holder area place?
are you talking about doing this in a 6th gen civic (96-00)? if so then you do not need anything. you take out the din at the bottom. route the radio wires down to the lower din area. you of course have to take out your center console to do this. once you take out the center console you will see behind the cupholders. there will be a couple holes on each side of the cage. find some bolts that will thread through those holes. they will hold the radio in place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoSoLow »</TD></TR><TR><TD CLASS="quote">are you talking about doing this in a 6th gen civic (96-00)? if so then you do not need anything. you take out the din at the bottom. route the radio wires down to the lower din area. you of course have to take out your center console to do this. once you take out the center console you will see behind the cupholders. there will be a couple holes on each side of the cage. find some bolts that will thread through those holes. they will hold the radio in place.</TD></TR></TABLE>
thanks man
thanks man
Unjockable
Nov 23, 2002 01:54 PM
