2006 accord Audio system questions plz hlp~!
Hey ive got a 2006 accord 4 cyl, I want to hook up to my factory head unit to my 12 inch audiobahn to my 2 channel mtx amp.. Ive got everything done besides hooking up the high level inputs/rca connections.. My amp has the level inputs built into the amp... Do i need a line out converter still or can i just hook up to my rear speaker wires behind the head unit.. The plug for the line input has 2 positive 2 negative for right and left.. Also what would be the best place to get my remote wire? Would the constant on the deck be a ok spot?? Thanks for your time...
Pat
Pat
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Most new entry level amps have built in loc. You can get signal from your rear speakers. That would be fine if you don't want to buy a loc. Tag the remote to your acc or put it on a switch. Don't put it on constant because the amp will never shut off and that would drain your battery
Ya thats right i didnt mean to say constant i meant to say accesories... Thanks for your help, would it matter if i ran the line input wires along with the power and remote wire or should i run it on the opposite side??
Pat
Pat
k1ngkev1n1
Jul 1, 2008 09:06 PM
Ghostyman
Audio / Security / Video
Aug 30, 2005 05:08 PM
