car bogs after i let it sit for a week? confused.
Old Jul 31, 2006 | 06:33 PM
pearl's Avatar
Default car bogs after i let it sit for a week? confused.
i drove from NJ to MD, and back in one day. car was fine, 100%. i left for vacation the next day, come back and start it up. i have a big gas leak. WTF?
i end up replacing return line on the fuel rail (reg to firewall). there was a bunch of dirt and crap in it. kinda scary. cleaned it out and put it back together.
--car bogs down low really bad at about 2500-3500 RPM's @ WOT and 1/2 throttle. --once i am in boost it is fine.
when i start it when it is cold (ex. let it sit over night) it wont stay on unless i give it gas. backfires a lot, bogs/studders etc.
i check and changed my plugs fuel filter, tried another FPR, there isn't any crap in my fuel rail or injectors
, no luck. car seems fine otherwise. anyone have any ideas?
y8 turbo, tuned ecu.
Modified by pearl at 6:41 PM 8/4/2006
Modified by pearl at 7:53 PM 8/4/2006
Old Jul 31, 2006 | 07:10 PM
Muckman's Avatar
Moderator in Chief
Default Re: car bogs after i let it sit for a week? confused. (pearl)
Maybe all the crap in your return line was clogging up your fuel pressure. Now that its gone your pressure is lower and your running leaner.
Old Jul 31, 2006 | 08:07 PM
pearl's Avatar
Default Re: car bogs after i let it sit for a week? confused. (Muckman)
i thought that as well. i ended up taking the vac. line off the FPR, same results.
Old Aug 1, 2006 | 03:26 AM
pearl's Avatar
Old Aug 1, 2006 | 04:56 AM
igo4bmx's Avatar
yeah sounds like pressure was lower, and you're leaning out.
Old Aug 1, 2006 | 05:11 AM
Muckman's Avatar
Moderator in Chief
Might want to replace your fuel filter if there is that much crap in your fuel system. Who knows what else is clogged... ie injectors.
Old Aug 1, 2006 | 12:21 PM
pearl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">yeah sounds like pressure was lower, and you're leaning out.</TD></TR></TABLE>
but how come when the car is in boost it feels fine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Might want to replace your fuel filter if there is that much crap in your fuel system. Who knows what else is clogged... ie injectors.</TD></TR></TABLE>
yeah im going to try and do the fuel filter today and see what happens... but its 112 degrees outsides in NJ right now. thanks for the input
Old Aug 1, 2006 | 12:39 PM
nonvtecD's Avatar
Get it retuned...
Old Aug 1, 2006 | 12:51 PM
pearl's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">Get it retuned...</TD></TR></TABLE>
would that make that much of a difference that i would need a whole new tune?
Old Aug 1, 2006 | 05:25 PM
pearl's Avatar
did the fuel filter, rechecked the plugs... i think i have a bad tank of gas. i drove to the gas station, put some fuel cleaner in and 10 bucks of gas, car seems to be getting better little by litte...
Old Aug 1, 2006 | 07:00 PM
95DxSi-R2
Guest
Posts: n/a
try some injector cleaner too. maybe that will help
the one you hook in line @ fuel rail.
Old Aug 1, 2006 | 08:09 PM
pearl's Avatar
Default Re: car bogs after i let it sit for a week? confused. (95DxSi-R2)
well it didnt get better, car still runs like complete ***.
i put the injector cleaner that you put in the tank before you put gas in it.
Old Aug 1, 2006 | 08:13 PM
95DxSi-R2
Guest
Posts: n/a
yea, but those really aren't worth it
Old Aug 1, 2006 | 08:24 PM
pearl's Avatar
i was told my FPR might have taken a **** as well. i hate this car.
Old Aug 2, 2006 | 01:00 PM
pearl's Avatar
bump because this is pissing me off. havent touched the FPR yet.
Old Aug 2, 2006 | 03:36 PM
pearl's Avatar
the FPR i had doesnt fit (z6 fpr doesnt fit on a y8 )
i did run the car with the vaccum line off of the FPR, and I had the same results. same bogging and crap as before.
with that said, is the FPR is bad?
Old Aug 2, 2006 | 07:23 PM
swoyEKr.'s Avatar
omg, b series time
Old Aug 3, 2006 | 07:29 AM
nonvtecD's Avatar
A B series will nto fix these problems. You need to get a wideband on it and re-tune. If that doesn't fix it then you look elsewhere but you're running non-stock engine management with a non stock setup so that needs to be taken care of.
Old Aug 3, 2006 | 08:26 AM
pearl's Avatar
yeah, i think a tune is the last resort for me. im going to check the fuel pump out too. if i start the car it usually shuts right off, unless i give it gas.
Old Aug 3, 2006 | 06:47 PM
gsr dood's Avatar
Default Re: (pearl)
no cels???? cuz the same **** hapened to me on my NA integra. it ended up being the iacv that was clogged. it wouldnt stay on unless i gave it gas....but after 3k rpms, it would run fine.
Modified by gsr dood at 11:12 PM 8/3/2006
Old Aug 4, 2006 | 01:30 PM
pearl's Avatar
Default Re: (gsr dood)
nope, no check engine lights at all. i guess ill take my iacv off and clean it up i guess.
this is really annoying
Old Aug 4, 2006 | 01:58 PM
igo4bmx's Avatar
i would serious run stock ecu and stock injectors and see what happens
Old Aug 4, 2006 | 02:22 PM
pearl's Avatar
Default Re: (igo4bmx)
not a bad idea. ill have to check that out too.
Old Aug 4, 2006 | 02:37 PM
sorrule's Avatar
i put one of those cheap ebay b&M fpr in my car it it does the same thing almost. If I let is sit over night and I start it up the next day, it starts up and then chokes a bit then idles fine. But when i drive it is chokes at low rpm and then after drive for 5mins it returns to normal? seems like it's not holdin pressure? Might just get an aem one.
Old Aug 4, 2006 | 02:39 PM
pearl's Avatar
Default Re: (sorrule)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule &raquo;</TD></TR><TR><TD CLASS="quote">i put one of those cheap ebay b&M fpr in my car it it does the same thing almost. If I let is sit over night and I start it up the next day, it starts up and then chokes a bit then idles fine. But when i drive it is chokes at low rpm and then after drive for 5mins it returns to normal? seems like it's not holdin pressure? Might just get an aem one.</TD></TR></TABLE>
my car doesnt return to normal, it keeps choking at that rpm range no matter what. ive had the car outside idling for 30 minutes and still does the same thing.
