Main relay with 4 wires?
Old Jul 31, 2006 | 06:20 PM
broken crx's Avatar
Default Main relay with 4 wires?
I bought a 1991 CRX with the B16A swap and have been having touble getting it to start in hot weather. I have already changed the main relay, but the fuel pump only kicks on and the relay only clicks about 75% of the time I turn on the ignition? Also, the schematic in the shop manual shows 7 wires going into the relay and mine only has 4 wires and none of them read over one volt with the igniton on or the car running? What am I missing here? I really want to like Hondas, but this thing is pissing me off.
Old Jul 31, 2006 | 09:27 PM
jdmef2er's Avatar
look at the ground nead the termes... they might be lose!
Old Aug 1, 2006 | 02:54 AM
7PSI CRX's Avatar
Default Re: Main relay with 4 wires? (broken crx)
You have replaced a relay,
NOT the MAIN RELAY.
The MAIN RELAY looks like this.
Is this what you changed?
No......
Go to HONDA and buy a Main Relay.
Problem solved.
Old Aug 1, 2006 | 03:02 AM
sierrakilo's Avatar
Default Re: Main relay with 4 wires? (7PSI CRX)
Could be bad solder joint on the main relay board... before just blindly buying another one, why not pop off the board and have a look at the solder on the bottom of the board? use a magnifying glass and look for cracks around the pins. Mine had several that were 'cold' joints. Touch them up with a hot solder iron, plug it back in and see what happens. You've already got it out, its not much more work to save yourself some $$$ on a part you might not need.
turbocivic1984
Jun 29, 2008 09:59 AM
90civicturboed
Jul 29, 2005 08:47 PM
SOHCwarrior
Jul 4, 2005 05:40 PM
flip1199
Feb 23, 2005 04:41 PM
